I am not quite ready to go 100% eFan route yet, but I am considering replacing the stock Auxiliary cooling fan with a more potent (more powerful) one.
Ideally, the replacement fan would require very little to no modifications, just have higher CFM rating. (By the way, what is the CFM rating of the stock aux fan?)
The stock fan is quite small. if you wish to keep the shroud, then buy a fan that will just fit into it, and fab up a mounting that will get it as close to the actual rad fins as possible. A decent make, SPAL are probably the best aftermarket fans available, will be far better than the OEM one.
I pulled the stock Aux Fan from the donor car. To take a closer look at it. See the picture below. It is a Bosch fan, 12V. Diameter (blade-to-blade): 10.75" (or about 270mm). There are no other specs on it. Does anybody know what the CFM rating on this fan? And whether it is a pusher or a puller?
In general, what kind of aux fan should I be looking for for max performance: a puller or a pusher?
I think it should be a puller, right? (But, as usual, one can always find divergent opinions on the internet )
If you mount a fan in the Aux bracket area and its pushing wouldn't the car up recycling the same hot air? I'm also interested in a new aux fan, I've wired mine to a toggle switch for hot city traffic and hot shutdown.
This morning I "cleared" the area after removing the Aux Cooling Fan and then took some measurements. It appears that there should be enough space to fit 11" or even 12" eFan in the space.
I am thinking about finding the most powerful eFan (hopefully, 12") that would fit in the space to replace the stock fan. If anybody already did this, please share your experiences/advises/references... Tnx!
That is what I have done. remove the shroud and you can get in a 12 inch, just, or an 11 inch. The 12 may slightly overlap the LHS radiator tank but that does not matter. I have a SPAL in the biggest motor they make for the size. Works fantastically well.
Fixing well it is important. I have mine hung from the crossplate at the top (I bolted an ally square tube underneath the crossplate, just aft of the rad, and fixed the top of the fan to the tube) and I welded studs to the crossmember under the rad for the bottom, with support arms from the studs up to the fan bottom fixings. Or you could fab an ally shroud, bolt the fan to it, and use the OEM fixings, But get the fan as close to the rad as you can, with a bit of foam stuck to the fan outer rim to stop any chafing.
I have twin E fans, and the main fan, another huge SPAL basically never cuts in except in traffic jams on a boiling hot day.
I have a cheapo $20 fan from eBay, required minor cutting to the shroud. I think it is rated in the range of 2200-2500 CFM. Some figures floating around suggest the stock fan ran around 850-1000 CFM. Mines lasted 6 years so far and is a $20 fix if it goes bad, so I have no desire to go with a fancy branded $100 electric fan.
I'm interested in this, too. I used to live in a cold Nordic country and I remember I removed the original clutch and fan. Replaced it with something electrical ... it was almost 20 years ago. Now I live in hot climate and my old setup is not likely sufficient. What brand you got from eBay?
