relay 33374b replacement
Received 10,891 Likes
Is this for the electric cooling fan?
Are there numbers next to the terminals? Are they 30-85-86-87a-87? If so that's a very common configuration. You can buy one at most auto parts stores, radio shack, stereo installers, umpteen on-line vendors.
sidescrollin (09-09-2011)
Here's one:
12 VDC Automotive 5-Pin Relay SPDT 30/40A Bosch Type
You can get with/without the mounting tab, metal or plastic case.
I should add that, although it's straightforward in *this* case, there are other relays on your car that look the same but are slightly different....some have an internal diode, some have two "87" terminals rather than "87-87a", some have only four terminals.
So, if you're ever tempted to swap relays around be careful :-)
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
