Remote locking problem XJS
Hi
I recently bought a XJS convertible 1990 and the remote locking does not work. I have already spent some time googling this to no avail.
The remote has no indicator light so I don't know if it even works. I have tried replacing the 9v battery but it still won't work.
Where do I start looking to solve this problem? Any help would be appreciated.
Thanks Weenie
Ps I did also buy the below book but not much technical detail in it but interesting read.
JAGUAR XJS BUYING MAINTAINING MODIFYING THORLEY
Thanks Weenie
@Weenie
If you have remote locking on a 90 car, it is either the Jaguar security system (which I believe was a dealer fit option) or an aftermarket system. Does the remote have a jaguar on it ? or it's just a little black box ? Do you have an LED and a switch marked "Valet" somewhere on the steering column ? (This suggests it's a Jaguar system....).
There is another post on here from another member who has a working Jaguar security system, but we still don't know exactly how it all works. You may want to try some of the things suggested on this thread..... https://www.jaguarforums.com/forum/x...es-work-80377/ at least to see if you have an alarm system. I imagine there is a way to "learn" the remote to the car after the battery change, but I don't know the procedure.
Hi Sarc
The fob is half the size of a match box with a single button in the middle. The button is domed clear plastic with the gold jag head inside so I presume it is factory fitted.
I will have a look for the led and switch at the weekend but,I,dont remember seeing anything.
I also don't have the documentation for the car yet but are planning to pick it up from the old owner at the weekend. I will keep you posted on this.
Thanks for you too far....
Weenie
Weenie
Hi Darren
Ok, sounds like a factory system then....... if you get the manuals and they do have a sub section on the alarm/remote locking, it would be great if you could share it. These questions have been coming up a lot recently and no one has a really good answer about how these systems are supposed to work
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
