Removal of smog equipment
In other threads members mention a kit to “replace the plugs” when the smog equipment is removed and an idler pulley for the belts. Where did you get the factory style plug kit I would use when i removed the smog system. Also , who did you order the idler pully from? I would like to clean up my engine compartment too.
Bando 3430 belt goes from AC to crank pulley apparently, thus eliminating the need for a tensioner? As for the plugs I tapped them where the little pipes went in and inserted these set screws with jbweld etc, not show car perfect but it worked. You can buy a nice set where its all machined perfectly but they were way over priced.
Received 10,920 Likes
thank you , this looks like the way that I will go. I just now need to see source the pulley and figure out what I can and cant take off.
Gus
07-27-2015 03:35 PM
Staatsof
07-20-2010 07:05 AM
Jaguardoc504
01-05-2010 12:00 PM
