Removing the ABS sensor
Hola muchachos,
My sig isn't showing up so I'll tell you, mine is a '94 V12 coupe, UK spec.
I'm at the part of the tear-down where I drop the front and rear subframes. And I'm stuck on the bloody ABS sensors.
I've undone the bolt, doused in WD40 and juuuust about managed to get it to shift a tiny touch, but the little buggers are hanging on like limpets.
How do you get them off, do they just pull? Anyone found a good way to get any grip on them?
Rear hub, looking down from top
Disconnect the other end of the cables from the interior. Lift the back seat, disconnect and pass through the floor grommets on both sides. this will be easier in the front because you don't have to remove any interior parts.
You have to soak from the underside. where the sensor sits inside the up right.
Thank you.
Larry Louton
Thank you.
Larry Louton
