Removing the AC evaporator
Old 12-14-2011, 09:21 PM
robinlarry's Avatar
Default Removing the AC evaporator
Any suggestions on how the access the AC evaporator? I've removed the center console, glovebox, and radio. The manual I have is very sketchy. It says I need to remove the fascia (dash). Is that really necessary and if so, how do you do it?
Old 12-16-2011, 10:56 PM
robinlarry's Avatar
My service manual cd says that 76.46.01 shows how tgo remove the fascia. Unfortunateoy, the disk doesn't include that operation. Anyone have a copy?
Old 12-16-2011, 11:23 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
I have a hard copy if no one comes up with a copy before Monday I'll take it work and scan it. My MFC is no-op at the moment.
cheers
Warren
Old 12-17-2011, 07:24 AM
robinlarry's Avatar
THanks Warren. I've removed the two bolts on the bottom of the outside of the dash. Started removing the instrument panel. I just can't tell from the parts manual whether there are other bolts in there yet.
Old 12-17-2011, 08:41 AM
Received 8,180 Likes on 4,934 Posts
The last one I did was a 16 Hour Job. YES the entire 'dash' to the bulkhead must be removed to gain access to the climate control box.
Pinch the heater hoses and plug the metal line to prevent coolant from spilling into the cabin when the 'box' is hauled out the passenger door.
bob gauff
Old 12-17-2011, 03:51 PM
robinlarry's Avatar
Default Removing dash
Well, I found the top bolts ... dash is loose and ready to come out. '
Did you have to drop the steering wheel to pull the instrument panel out to make room to get the dash out?
Old 12-17-2011, 04:23 PM
warrjon's Avatar
You need to remove the steering wheel. Here is an extract from the ROM
1 Remove pinch bolt securing steering wheel and adjuster mechanism to upper column
2 Slacken locknut and allen screw adjacent to pinch bolt.
3 Remove steering wheel and adjuster from upper column.
cheers
Warren
Old 12-18-2011, 07:51 AM
robinlarry's Avatar
It's out. No mess since the coolant was drained from the engine already.
Old 12-18-2011, 02:27 PM
warrjon's Avatar
As promised
File Type: pdf
Old 12-19-2011, 12:58 PM
xjs40l's Avatar
Took me 19 hours for the job. Much joy and many photo's and plastic baggies.
While you are in there check ALL of the vacuum lines and the vacuum valves. Use this opportunity to repair/replace/retrofit what you can while you have the dash disassembled.
Old 06-20-2021, 12:07 PM
Magna1969's Avatar
Originally Posted by warrjon
As promised
What manual are you using the one i have is terrable!!
Old 06-21-2021, 09:37 AM
Dukejag's Avatar
Post some pictures, interested to see how it looks with the dash out etc,
Good work!
What is the plan for the box?
Old 06-21-2021, 11:42 AM
ptjs1's Avatar
Received 3,109 Likes on 2,052 Posts
It's a pretty daunting job both to take out, but especially to put it all back! I once helped a colleague do it on a 6 litre. It made me hope I would never have to do it on my car!
Here's a pic I found of a RHD HE car with the dash and aircon out. Be afraid, be very afraid!
Paul
Old 06-21-2021, 03:40 PM
mghirsch's Avatar
I am reassembling mine. !4 months into a 2 week job. (Work, too hot in the garage, rotator cuff repair). Good luck.
aholbro1
08-05-2021 05:02 AM
dsnyder586
04-04-2019 02:38 PM
Russ Graber
02-23-2019 11:59 AM
Saturbo
09-08-2015 07:35 PM
Quick Reply: Removing the AC evaporator
