Removing door panel
Hey everyone, so jaguar doesn't have the window I need so I got one off ebay. The one thing I cannot figure out is how to take off the driver side door panel. I got the screws and popped most of the plastic pieces. However, I cannot find what holds the arm rest on. I don't see screws but it doesn't feel free floating. Any suggestions? thanks guys! -Adam
yeah thats exactly it,pull back the metal trim on the part of the armrest furthest forward and there should be a big philips head screw.
There are tabs inside the panel so yeah, you have to lift up. I have replaced my door handle and my speaker. its pretty easy but tape off the leather before that metal ring or itll get scruffed up
i have the one chrome part off on the front end. and got the screw out. are there more screws on the back side of the armrest or is the arm rest kind of attached to the panel itself? if you are able i would like pictures haha i am slightly lost. Thank you -Adam
XJSPaul
Do you recall what kind of tape and lubrication you used? I tried pulling back the chrome surround and it was so tight I didn't think tape would protect the leather there so I stopped trying. TIA.
you can put anything liek duct or masking tape on it and then the oil or whatever is just to help it slide, its not THAT bad but if you do it a couple of the times the chrome piece will make the surface rough and its real bad for the stitching.
the chrome simply pops on and off another piece of metal so its a matter of using enough force. Try using a flat blade screwdriver but don't use the end to pivot, put your finger halfway up or something and pivot off that.
or jsut hold it halfway down and dont pivot the screwdriver but rather use it to pull on the chrome while you wiggle it with your free hand.
i always hate interior stuff because the line between breaking and coming apart is so fine and most of the time we all thing its going to break.
Thanks, I'll try the masking tape/oil. I did manage to get the chrome piece off of the piece of metal holding it on, but even after that it was so tight it was going to scuff up the leather. It's actually already scuffed a bit from the previous owner as he put in aftermarket speakers.
99xk8guy
06-05-2023 06:28 AM
