removing wood dash plate around computer
Regular,
You need to gently remove the switches in the veneer on the immediate left and right of the trip computer in order to access the mounting bolts for the trip computer.
Once the trip computer is removed, you can then carefully pry off the veneer from the dash with the other switches attached and then remove the switches and wiring from the veneer.
The veneer is held to the dash via 2 pins that push into nylon mounts on the dash.
Hope that helps
Paul
Hope that helps
Paul
From memory, thosexswiches are held into the veneer by the typical plastic tangs, so go easy.
Then there is a small bolt (iirc) on each side of trip computer mounting it to metal brackets. Then you put the computer out and disconnect the wiring plug.
Then you pry off the veneer carefully together with the other switches still attached by their wiring plugs.
On mine, the veneer is held to the dash frame by a pin each side that is part of the veneer that pushes into a plastic grip eyelet hole that is pressed into the dash frame.
Paul
Paul
The "pair of buttons" that I was referring to exist on either side of your trip computer. Those are friction mounted with metal clips. Dig your fingernails around the bezel and pull them out.
That will reveal the connection and allow you to remove the wood trim. That wood trim holds not only the trip computer, but both "pairs of buttons" on both sides. You need to get those buttons out before you can attack the trip computer and frame.
