Replacement headlamp dip relay
My headlamp relay failed on my 83 XJS and the replacement was pricey. I searched around and found a readily available, inexpensive replacement.
It is listed as a sunroof relay for a 2001 Cadillac Eldorado
and carries part number of BWD R3018. $24.49 at the local
auto parts store.
It dips the headlights as normal and also has the ability to
flash the high beams. There is a schematic on the side of
the relay.
I hooked it up as follows:
S - Grd
30 - Dip/flash from switch
56 - headlight power from switch
56a - high beams
56b - low beams
I am still running lights via the fuses, but intend to upgrade the fuse box shortly as well as adding high current relays to handle the headlamps
in order to manage the current of my H4/H1 lamps.
auto parts store.
the relay.
S - Grd
56a - high beams
56b - low beams
Received 10,936 Likes
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
