Replacement Muffler for Facelift
As I continue collecting the parts required to restore my 1996 XJS, AJ16, I found that the passengers side muffler is gone. It was probably ripped off when it was towed out...that's a story covered in another topic. Anyways, that muffler is gone, and it was ripped out at the muffler, so the two clamps and pipes attached to them are fine.
I need to find a replacement muffler. A google search isn't very helpful. Can anyone help? Should I even consider buying a used one? Its the rear passenger muffler. Part #NHE6770AB
Thanks.
Thanks.
Received 10,916 Likes
The link you provide suggests that the muffler is still available from Jaguar. Click to buy. Or, call your local Jag dealer with the part number. Listings from several Jag specialists suggest the same.....although I'd call first before sending payment ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
That said, I see no problem with getting a used muffler if it looks to be in good shape
chXFS
05-30-2022 11:02 PM
CruizinKev
10-09-2017 09:12 AM
