Replacing Brake fluid
Received 10,880 Likes
You'll never see the recommendation in the manual for a USA made car
However, Euro, UK, and Asian cars have had the recommendation for decades
Old, contaminated fluid boils more easily...and that's bad. Plus, brake fluid absorbs moisture which is bad for the hydraulic system and further lowers the boiling point.
You'd need to take the fluid from the reservoir first. Then put some new brake fluid in. Then bleed each caliper, some calipers have two bleeding points actually. Make sure no air bubbles get in while bleeding. To accomplish the no air bubble entering the caliper put a container with clean brake fluid and take a hose from the caliper nipple to the container and keep it in there at all times.. If need you more thorough explanation let me know. Also one way to bleed is to have someone pump like three times the brake then keep his foot on the brake while pressing down while you bleed the caliper. You need to do this until you see the clean oil coming out into the container..
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
