Replacing drive belts
It's easy - takes an hour. And you don;t have to remove the hood.
First remove the air cleaner and ductwork so that you have clear access to the alternator. Working from top and bottom, loosen all of your adjusters. The AC belt comes off first and the alternator belt will fit up over the fan - very easy to do. Install your new belts, adjust tension and away you go.
bigwiki (01-16-2011)
BrentGardner
28
04-26-2024 03:08 AM
Fraser Mitchell
10-01-2015 04:06 AM
Will P
08-27-2015 06:52 PM
