Replacing engine oil cooler hoses.
The oil cooler bypass on a 4 litre is done using parts 3,4,5,6 & 7 on the Jaguar diagram here:
Oil Filter-3.2/4.0 Litre - Parts For XJ Series from (V)720125 to (V)812255 (X300) | Jaguar Heritage Parts UK
They go for about £40 / $65 second-hand. Have a look on ebay.
Paul
Paul
RagJag (06-19-2015)
ptjs1, since I can't see the openings in #5, I need to know if the openings are blocked off. If so I can remove it and block them off in my workshop. By doing this I can eliminate the seep from the flex hoses and the concern that the old flex hoses will spring a leak. Then to the other chore of removing the Tupperware under skirt to access the cooler for removal.
Thanks, RagJag
Thanks, RagJag
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
