Replacing Intake Manifold Gasket-What else??
Vee (08-16-2015)
Vee,
I would change the water rail pipe as it's a pain to get to otherwise and it's block connection does leak. Also, just because it's easier at the time, also check the heater valve and it's inlet and outlet hoses. I'm just about to replace my heater valve (which only leaks when it's turned off).
Good luck
Paul
Good luck
Paul
Vee (08-16-2015)
rachelstr
09-03-2015 12:59 PM
