Replacing Window Switch’s
The following 2 users liked this post by Vee:
Greg in France (12-11-2023),
JJS- Florida (12-13-2023)
I also have a vague recollection of having to pries out the catch receptacle for the armrest in order to remove the metal bracket that spans across the very rear of the ski slope but it was a while ago when I did this.
Cheers,
LeeP
You shouldn't have to remove the ski slope, just tilt it high enough to unplug the two or three switches you have, and then pry out the entire bezel assembly. then do what you want. Just make sure you remember which plug is which! They are all the same, so you run the risk of plugging the drivers side switch to the passengers side plug.
Also, if you bought the cheap replacement switch with the plastic tabs, the only way I was able to squeeze the switch into the bezel was after heating the tabs up on the switch with a hairdryer.
