Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old 04-04-2020, 04:02 PM
Rescue119's Avatar
Originally Posted by orangeblossom
Hi Rescue
If you've Burned out the Brake Pump, then you won't hear it running and trying to prime the system when you turn the Ignition on, also the ABS Light probably won't go out although that could be also due to having the Rear Brake Pads missing and you'll probably wreck the pistons in the Calipers as well
Well the abs light wasnt on and I'm replacing everything in the rear end anyways with remags.
There a lot of noise when u turn on the ignition lol.
  #302
Old 04-04-2020, 04:33 PM
orangeblossom's Avatar
Received 3,812 Likes on 2,639 Posts
Hi Rescue
That noise you hear is probably the Brake Pump trying to build up pressure to prime the System, which is not supposed to be running for more than the recommended 15 Seconds with out a 2 Minute Cool down before you turn the Ignition on again
Hopefully you got lucky and the Brake Pump is still OK but maybe the next time 'The Jaguar Gods won't be with you'
  #303
Old 04-04-2020, 04:38 PM
Rescue119's Avatar
Hi Rescue
Fingers crossed lol. Thanks for all the input. I know once I get my jag turned around and oriented properly in my garage I'll be dropping the cage. You post is definitely an inspiration.
orangeblossom (04-04-2020)
  #304
Old 04-04-2020, 05:18 PM
JayJagJay's Avatar
Received 1,296 Likes on 897 Posts
Hi Rescue
Hopefully I'm not too late but if you try and Start her up or even turn the Ignition on with either the Rear Flexy Cut or the Rear Brake Pads out
Then you will almost Certainly Burn Out The Brake Pump, even if the Front Brakes feel like they are working
If your driveway is level then you would be best to roll her out and then Chock the Wheels so She can't roll away
Hi OB...
After reading your post I'm afraid that I gave Res some disasterous advice... Are you saying that if you clip that soft brake line and COMPLETELY seal the end so it maintains pressure,,, that the pump will continue to run until it burns out? Won't it reach right pressure and then shut off with the hose end sealed? Or, is it because there is air in the line that it will NEVER reach a pressure that will shut down the pump?
  #305
Old 04-04-2020, 10:52 PM
Hi Jay
No if anything you probably saved the day, as long as the pump was able to shut down soon enough to prevent itself from over heating
JayJagJay (04-05-2020)
  #306
Old 04-05-2020, 09:05 AM
JayJagJay's Avatar
Hi Jay
Shweeeew... Thanks for the reassurance, OB...
I find myself offering "tips" and "advice" lately, then later second guess and doubt myself - which makes me wish I hadn't. Would hate the be the cause of trouble for someone out here... especially a costly or catastrophic piece of bad advice.
  #307
Old 04-05-2020, 09:11 AM
Rescue119's Avatar
All good jay. No worries. There are companies that rebuild them and I've seen used ones for sale if I need to.
I think my vice grips are holding the line tight. I'm taking a jag day off today. I'll get back at it tomorrow. Next problem is to figure out the shifting.i ordered the vacuum modulator which iirc the previous owner had mentioned there was a tranny shifting issue and they though a line had come off. Hopefully it's an easy 30 dollar fix. Part isnt here til Thrusday at the earliest. So while I wait I'm gonna get the jag back up on the stands and start cleaning the engine bay a little from dirt and debris.
Also wife wants me to build garden boxes so that's gonna eat up a day or too.
I am a man of many talents lol.
Remember if the women dont find ya handsome...they can find you handy.
The following 2 users liked this post by Rescue119:
Dukejag (04-07-2020), JayJagJay (04-05-2020)
  #308
Old 04-06-2020, 09:49 AM
Rescue119's Avatar
emptied the trunk out. Just puttering. Next partnwont be here til end of week. Trying to avoid yard work haha.
Also for some reason PO needed to replace 2 tires but he put 195/60 on as a replacement. Cheap I guess. Anyways they were on the back while the fronts had the P600 225/60.
So I switched them around the other day so the small tires are on the front and bugge run back. Actually looks good stance wise. They all need replacing anyways once I get to that point down the road.
wife took this pic while I was trying to move it.
  #309
Old 04-06-2020, 09:11 PM
Rescue119's Avatar
  #310
Old 04-07-2020, 11:45 AM
Rescue119's Avatar
Got the transmission governor out today it was full of oil lol.
  #311
Old 04-07-2020, 02:44 PM
JayJagJay's Avatar
I've never never touched one...
What's it supposed to look like? Really tho...?
  #312
Old 04-07-2020, 03:31 PM
Rescue119's Avatar
It's just like it shows. It slides into a hole on passenger side of transmission. Has a vacumm hose going into it. Regulates the shift points. Not expensive part and know to fail. The membrane inside ruptures. Just held on by a 1/2" bolt and bracket. Took longer to crawl under car then to remove it.
So if you are having shift issues or rough shifts it's an easyauto replace and clear up hopefully the issue. They make adjustable ones so you can change the shift points a little. Just a screw in the middle.
Just google th400 transmission governor.
I forgot Friday is Easter so I hope the part is here on Thursday. If not wont be til next tuesday lol.
Oh well more time on yard work which I did most of this morning til lunch. Then went for a spin on my motorcycle.
Time to bbq some steaks
good pic shows location.
  #313
Old 04-07-2020, 03:46 PM
Dukejag's Avatar
Cool looking garage, nice and tidy, length wise looks like it could be a bit tight?
Hard to tell from this angle.
Man is that one huge fuse box..... does each light bulb get it own breaker?
And only 1 x empty beer bottle!
And I have to ask, why do you have what looks like a cage in the top back corner of your garage?
Love looking in people sheds.
Car looks great!
  #314
Old 04-07-2020, 03:55 PM
Rescue119's Avatar
Car looks great!
Lol 220 amp fuse panel. New houses have 2. One big on and one small one. I have just the one large one. But it's a 3 bedroom 3 bath house about 2500 sq feet. I dont have power issues lol
my bench behind the jag is 2 feet and I have about 2 feet behind the jag to the bench. I have about 1 ft in front of jag when door closed. So ya it's a little tight.
That is my 240 volt heater I put in to keep the garage above freezing in winter. Hydro goes up but worth it. And when I want to work in there during winter I can crank it and it warms the garage pretty good.
I recycle lol
Old 04-07-2020, 04:13 PM
Dukejag's Avatar
Heater..... I want one!
That is one large 3 bedroom house....
Keep the updates coming, really enjoying them.!!!
  #316
Old 04-07-2020, 06:47 PM
JayJagJay's Avatar
Oh. That's the vac modulator... Not the governor...
That's why I was a little confused at the pic on the bench.
Governor is under a plate a bit further back on the trans towards the rear of the car. Looks like this.
  #317
Old 04-07-2020, 06:53 PM
Rescue119's Avatar
Governor is under a place further back on the trans towards the rear of the car. Looks like this.
Oops my bad was typing with greasy hands. But you knew what I meant lol.
  #318
Old 04-08-2020, 01:43 AM
Greg in France's Avatar
Received 9,331 Likes on 5,475 Posts
Rescue
The vac pipe that goes from the modulator to the A bank vac takeoff is well worth renewing with a silicone rather than ordinary vac tube. The OEM tube deteriorates, the plastic 90 degree bend at the modulator end fails as well, and is best replaced with a metal one. When i chnaged my vac tube for a new silicone one during my rebuild, the change it made to the shifts was very noticeable; much more responsive to throttle position and crisp.
  #319
Old 04-08-2020, 07:07 AM
Rescue119's Avatar
Rescue
The plan is during winter to replace everything. Hoses, fuel injectors everything I can remove and get it in the engine compartment. Basically I want to rebuild the upper engine. I'll have the front bumper off since the rad needs to be redone
thanks for the advice.
  #320
Old 04-08-2020, 03:12 PM
Rescue119's Avatar
New lug nutz came in. Fit perfect. Not gonna use em for awhile but glad I found a set. And were on sale.
Quick Reply: Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
