Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old 05-16-2020, 04:36 PM
jag-reflex's Avatar
..spanner on the outside-the-cage end of the top fixing bolts is a bit of a wriggle though.
Yeah that was my limit, I sent my wife out for an air ratchet...much better!
  #502
Old 05-16-2020, 06:44 PM
Dukejag's Avatar
Look forward to seeing some pictures of your car in the air.
Air ratchets are good, don't use mine very often.
My sump is also leaking, there is a arm or lever of some sort on the side, mine is leaking from that seal.
  #503
Old 05-16-2020, 06:51 PM
Rescue119's Avatar
maybe the dip stick tube? I heard they leak.
I have electric and impact guns but i tend to try and not use those though
  #504
Old 05-17-2020, 01:01 AM
Greg in France's Avatar
Received 9,331 Likes on 5,475 Posts
Offset ring spanners are useful in this application too. If you search ebay for imperial ring spanners ther are loads dirt cheap. I just bought a full set of top quality ones for about 10 quid, as good now as they were when made 70 years ago.
https://www.ebay.co.uk/itm/Vintage-I...oAAOSw7SZelv6T
  #505
Old 05-17-2020, 04:33 PM
Rescue119's Avatar
Im always browsing for used tools around. Farm auctions are a good place for bigger items like welders presses etc.
Hell my boss got a car lift out of a VW dealership that was moving for 500 bucks.
  #506
Old 05-18-2020, 05:10 PM
Rescue119's Avatar
So while I wait for parts I decided to tackle the transmission filter.
I followed living with a classics video.
Man that transmission mount is time consuming. Especially when the exhaust can't come off. Lol luckily it was loose enough i could get a socket and extension onto those 2 smaller bolts.
Everything else went smoothly.
I'm gonna do the actually filter tomorrow at some point.
Oh and I'm glad I ordered a new transmission mount with my last order. There's not much left of it lol.
I also read but can't seem to find it about leaving something out or something like that to make it easier to do in the future? anyone know
Dukejag (05-18-2020)
  #507
Old 05-18-2020, 09:00 PM
Rescue119's Avatar
I was thinking that since I have the pan off should I install a b&m shift improvement kit. #20260 is the part number.
It says its for 68 to 87 ish th400s. Would my 88 th400 still be the same?
I figure for a 100 bucks it would be worth it. Looks pretty straight forward and now seems like a good time to put it jn.
  #508
Old 05-19-2020, 01:35 AM
The collision bracket, the heavy piece to the left of your photo can be left out. This makes it much easier to drop the tranny pan.
I would install a B&M adjustable modulator before doing anything else. This enables you to adjust shift points very easily and without having to undo anything. I reckon you will find that does enough.
Amazon Amazon
  #509
Old 05-19-2020, 05:41 AM
Rescue119's Avatar
https://www.amazon.com/20234-Adjusta.../dp/B000CIKBRM
So the part I circled....good
And this is the modulator I did put in a little bit ago.
  #510
Old 05-19-2020, 05:05 PM
Pawsnclaws's Avatar
Yeah, I'd throw the shift kit in. I've got one in mine, and it definitely makes a difference in the tranny's responsiveness.
  #511
Old 05-19-2020, 05:23 PM
Rescue119's Avatar
Today I didn't a little painting and cleaning of the tranny mount parts I've removed. Not much left of the original mount as u can see lol.
So my wife is gonna get me the 4 rear shocks for birthday/fathers day. She's like are you sure. Usually I get a tool and I could use a welder but I'd rather get the new shocks. Welder can wait til Xmas lol
  #512
Old 05-20-2020, 02:11 PM
Rescue119's Avatar
Got a bunch of parts. Tranny bushings, the big bushings for the radius arms, the park brake and rear brake pads. Also the rear brake hose.
Also got a sensor for the wife's ford edge abs. Took 30 minutes to replace. No more lights on dash. Ya. Still need a front wheel bearing for that. Should be hear tomorrow.
Still waiting on that bolt from the UK though.
  #513
Old 05-20-2020, 03:36 PM
Rescue119's Avatar
Wow. Glad I decided to do the tranny .
  #514
Old 05-20-2020, 07:21 PM
Dukejag's Avatar
That is it.. I am doing mine too....
Link to the living with a classic video - great help.
What are the part numbers for the new bits?
Keep the updates - really enjoy them.
  #515
Old 05-20-2020, 07:39 PM
Rescue119's Avatar
https://www.youtube.com/watch?v=ACb9aUCZJOw&t=780s
Lol . There was no filter element left lol.
Tomorrow I'm taking the radius arms to the shop to get the bushings taken out and new ones put in.
Grabbing a shift kit also. Then gonna spend the day cleaning up my mess I made and maybe ill get the kit installed. If not Friday. Taking my time as I haven't worked on a tranny before. And being in the car still is a little more time consuming.
Need to some petroleum jelly to hold stuff in place while i put it back together too.
  #516
Old 05-20-2020, 08:00 PM
Rescue119's Avatar
The mount bushing and rubber.
The filter is just a filter for a th400.
  #517
Old 05-20-2020, 10:31 PM
Dukejag's Avatar
Did you buy an aftermarket filter or Jag?
How hard to fit the shifter thing?
Have you read this thread on the shifter thing?
https://www.jaguarforums.com/forum/x...lation-102565/
I to am interested.... but as long as it does not add stress to the poor old transmission?
But I do like the idea of the car holding gear a LOT longer, mine seem to change SO early it disappointing.
Some time you just want to floor it and have it hold the gear until I relax my foot, and then it changes?
  #518
Old 05-20-2020, 10:36 PM
Rescue119's Avatar
The filter is just whatever the local napa store had.
The transmission the th400 etc have always been tough. They are still used today in muscle cars etc and can handle 450hp stock and its actually stronger than the 700r The v12 would fail before the tranny would.
As for fitting the kit I've never done ondoubt it really isn't that hard as long as you take your time and go step by step and not rush. Google th400 shift kit install on YouTube.
Installing while the tranny is in the car is a little more difficult and time consuming but if you can turn a wrench you can do it.
  #519
Old 05-20-2020, 10:44 PM
Rescue119's Avatar
Remember this is a very common gm tranny.
  #520
Old 05-21-2020, 08:55 AM
Rescue119's Avatar
I ended up going with the transgo shift performance kit after speaking with some transmission people. Was about double the price at almost 200cdn but has more options to tailor what I want. Its a stage 1/2 kit.
Today I'm gonna spend time just cleaning and getting everything ready.
Also dropped the radius arms off to get the new pushings put in.
Pics will be at end of day.
Weather is so nice its hard to stay in the garage now lol. Need to work on my tan.
Also perfect riding weather
Dukejag (05-21-2020)
Quick Reply: Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
