Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
#681
#682
#683
Update
steps include
How is the lower dipstick attached to the transmission? Does it just pull out? I felt and didn't seem like there was a nut securing it? I want to remove it now because its in my way to access the top cooler line.
New tools
11.99 on sale for the extension set.
9.99 for the 3/8 joint lol.
steps include
Disconnect battery ground cable and remove transmission dipstick.Remove bolt securing dipstick upper tube, then remove upper tube.Where is it? Top or bottom access? Answered. 7/16 access by feel from top Done.Position fender supports to allow installation of engine support tool, then attach engine support tool No. MS53B or equivalent, to engine lift brackets. Tighten tool hook to support engine weight.using jack/wood underneathDisconnect intermediate exhaust pipes and heat shields, then disconnect exhaust pipes from exhaust manifold.Remove front and rear heat shields and rear support center nut.Remove spacer, then using a jack, support rear mounting plate.Remove bolts securing rear mount, then remove rear spacers. Lower jack and remove rear mount.With rear of transmission supported with jack, remove crossmember.Disconnect driveshaft from transmission and position aside.Disconnect speedometer cable from transmission,then disconnect shift linkage.my speedo is in the differentialDisconnect kickdown switch electrical connector and remove bolt securing switch wiring clip from transmission.Disconnect modulator vacuum line, then remove clamp securing modulator and the modulator. Some fluid will drain from modulator housing when modulator is removed.- Disconnect oil cooler lines from transmission, then remove bolt securing oil line clamp to engine sump. got the bottom undone. Trying to get the wrench on the top one is kinda tricky. The the way it was finished tightening down i guess
Remove torque converter access cover.Remove bolts attaching converter to driveplate. Does the converter come out after? Answered!- Remove right side steering rack bellows heat shield, then remove right side catalyst from exhaust manifold, if equipped. Why? Anyone? Buller? Buller?
- Remove engine to transmission attaching bolts except two lower left side bolts and lower starter attaching bolt.
- Remove lower dipstick tube. Attach transmission jack to transmission and remove remaining engine to transmission bolts. Lower transmission and remove from below vehicle. Use caution not to damage right side catalytic converter when removing transmission.
- Reverse procedure to install. Tighten to specifications.
New tools
Greg in France (06-30-2020)
#684
#685
#686
And i just read the tranny dip stick just pulls out with some muscle. Gonna go see if i can wiggle it out.
#687
It is just a push-fit with an O ring, BUT the pipe, which is in two parts telescope together, is held into the box by that bracket I told you about. So pulling it up and out is impossible without bending the pipe unless the bracket is undone.
#688
#690
Rescue,
I love this thread; amazing detail. I have my rear cage out, largely cleaned up, and am replacing parts. I noticed you left off the U joint covers in the pics I saw. Are you leaving them off permanently? Does anyone think that's an issue at all? Mine are trashed, and look like crap. Would love to leave them off.
THX!!
THX!!
#691
Rescue,
THX!!
THX!!
#693
Update
steps include
So all that is left is the torque converter bolts...3? And then the bell housing bolts (ive counted 7 including the 12 point starter bolt but ive read there 8 or 6 of them. I'm gonna look but I can't seem to see any more. )
Thats is all for today
steps include
Disconnect battery ground cable and remove transmission dipstick.Remove bolt securing dipstick upper tube, then remove upper tube.Where is it? Top or bottom access? Answered. 7/16 access by feel from top Done.Position fender supports to allow installation of engine support tool, then attach engine support tool No. MS53B or equivalent, to engine lift brackets. Tighten tool hook to support engine weight.using jack/wood underneathDisconnect intermediate exhaust pipes and heat shields, then disconnect exhaust pipes from exhaust manifold.Remove front and rear heat shields and rear support center nut.Remove spacer, then using a jack, support rear mounting plate.Remove bolts securing rear mount, then remove rear spacers. Lower jack and remove rear mount.With rear of transmission supported with jack, remove crossmember.Disconnect driveshaft from transmission and position aside.Disconnect speedometer cable from transmission,then disconnect shift linkage.my speedo is in the differentialDisconnect kickdown switch electrical connector and remove bolt securing switch wiring clip from transmission.Disconnect modulator vacuum line, then remove clamp securing modulator and the modulator. Some fluid will drain from modulator housing when modulator is removed.Disconnect oil cooler lines from transmission, then remove bolt securing oil line clamp to engine sump.got them both undone.Remove torque converter access cover.Remove bolts attaching converter to driveplate.Remove right side steering rack bellows heat shield, then remove right side catalyst from exhaust manifold, if equipped.I don't think i need to do this so I will not. Theres nothing in my way. This list may be from a different version.- Remove engine to transmission attaching bolts except two lower left side bolts and lower starter attaching bolt.
- Remove lower dipstick tube. Ive tried but its getting hung up on the bracket.near the top of the ball housing. But its love and has give so should be ok.Attach transmission jack to transmission and remove remaining engine to transmission bolts. Lower transmission and remove from below vehicle. Use caution not to damage right side catalytic converter when removing transmission
#694
#695
Rescue,
THX!!
THX!!
About the covers. They will/can end up rubbing on things, come undone or partially, flop around. And they are quite old at this point. I was told by a resident GURU here, that it is FINE to leave them off. I chucked mine. Happily.
#696
The following 2 users liked this post by ChrisHarley2008:
Greg in France (07-02-2020),
Rescue119 (07-02-2020)
#697
#698
#699
#700
