Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old 06-29-2020, 03:37 PM
Rescue119's Avatar
Was out enjoying my bike today along the lake. I mines the one on the left. Did 350km today.
The following 3 users liked this post by Rescue119:
Dleit53 (07-01-2020), Dukejag (06-30-2020), eurolat (06-30-2020)
  #682
Old 06-30-2020, 05:01 AM
Dukejag's Avatar
Nice day for a ride!
Winter here so I have not been out for a while!
  #683
Old 06-30-2020, 11:49 AM
Rescue119's Avatar
Update
steps include
  1. Disconnect battery ground cable and remove transmission dipstick.
  2. Remove bolt securing dipstick upper tube, then remove upper tube.Where is it? Top or bottom access? Answered. 7/16 access by feel from top Done.
  3. Position fender supports to allow installation of engine support tool, then attach engine support tool No. MS53B or equivalent, to engine lift brackets. Tighten tool hook to support engine weight.using jack/wood underneath
  4. Disconnect intermediate exhaust pipes and heat shields, then disconnect exhaust pipes from exhaust manifold.
  5. Remove front and rear heat shields and rear support center nut.
  6. Remove spacer, then using a jack, support rear mounting plate.
  7. Remove bolts securing rear mount, then remove rear spacers. Lower jack and remove rear mount.
  8. With rear of transmission supported with jack, remove crossmember.
  9. Disconnect driveshaft from transmission and position aside.
  10. Disconnect speedometer cable from transmission, then disconnect shift linkage. my speedo is in the differential
  11. Disconnect kickdown switch electrical connector and remove bolt securing switch wiring clip from transmission.
  12. Disconnect modulator vacuum line, then remove clamp securing modulator and the modulator. Some fluid will drain from modulator housing when modulator is removed.
  13. Disconnect oil cooler lines from transmission, then remove bolt securing oil line clamp to engine sump. got the bottom undone. Trying to get the wrench on the top one is kinda tricky. The the way it was finished tightening down i guess
  14. Remove torque converter access cover. Remove bolts attaching converter to driveplate. Does the converter come out after? Answered!
  15. Remove right side steering rack bellows heat shield, then remove right side catalyst from exhaust manifold, if equipped. Why? Anyone? Buller? Buller?
  16. Remove engine to transmission attaching bolts except two lower left side bolts and lower starter attaching bolt.
  17. Remove lower dipstick tube. Attach transmission jack to transmission and remove remaining engine to transmission bolts. Lower transmission and remove from below vehicle. Use caution not to damage right side catalytic converter when removing transmission.
  18. Reverse procedure to install. Tighten to specifications.
where I'm at so far. Just puttering. Comments in red.
How is the lower dipstick attached to the transmission? Does it just pull out? I felt and didn't seem like there was a nut securing it? I want to remove it now because its in my way to access the top cooler line.
New tools
11.99 on sale for the extension set.
9.99 for the 3/8 joint lol.
Greg in France (06-30-2020)
  #684
Old 06-30-2020, 12:56 PM
Rescue119's Avatar
Ordered the repair kit I posted earlier. Says it should be here by Friday.
  #685
Old 06-30-2020, 12:57 PM
Greg in France's Avatar
Received 9,413 Likes on 5,516 Posts
The cooler fittings are a pain. If you remove the lower one out of the way, you can get better purchase on the upper one.
Have you got your 12 pint (double hex) 7/16ths socket for the top starter bolt yet?
  #686
Old 06-30-2020, 01:00 PM
Rescue119's Avatar
Yes I have a complete set of 12 points for both sae and metric.
And i just read the tranny dip stick just pulls out with some muscle. Gonna go see if i can wiggle it out.
  #687
Old 06-30-2020, 01:08 PM
It is just a push-fit with an O ring, BUT the pipe, which is in two parts telescope together, is held into the box by that bracket I told you about. So pulling it up and out is impossible without bending the pipe unless the bracket is undone.
  #688
Old 06-30-2020, 01:11 PM
Rescue119's Avatar
The top part i got out today. Got to use one of my new extensions 🤗 . I had to get the socket on it first then the extension. Used a magnet to grab it as i pulled it out.
  #689
Old 06-30-2020, 03:14 PM
Rescue119's Avatar
Took out that 12 point. Also got the filler pipe to move a bit to let me get a wrench in the top one. I couldnt get it to break free so I'm letting it soak overnight and ill try again tomorrow.
Good news is my rebuild kit already shipped!
Might drop the trans this weekend
Dukejag (07-01-2020)
  #690
Old 07-01-2020, 12:45 PM
Rescue,
I love this thread; amazing detail. I have my rear cage out, largely cleaned up, and am replacing parts. I noticed you left off the U joint covers in the pics I saw. Are you leaving them off permanently? Does anyone think that's an issue at all? Mine are trashed, and look like crap. Would love to leave them off.
THX!!
  #691
Old 07-01-2020, 12:59 PM
Rescue119's Avatar
Originally Posted by ChrisHarley2008
Rescue,
THX!!
They are just dust covers. And not very good since the one side is open so to me stones etc could get jammed in there. Plus they access hole plugs were half missing. They are off and will remain off.
  #692
Old 07-01-2020, 01:00 PM
Mguar's Avatar
The purpose of the covers is to protect against road debris and water splashes. Considering most U-joints don’t have those I leave them off the race car.
Rescue119 (07-01-2020)
  #693
Old 07-01-2020, 01:05 PM
Rescue119's Avatar
Update
steps include
  13. Disconnect oil cooler lines from transmission, then remove bolt securing oil line clamp to engine sump. got them both undone.
  15. Remove right side steering rack bellows heat shield, then remove right side catalyst from exhaust manifold, if equipped. I don't think i need to do this so I will not. Theres nothing in my way. This list may be from a different version.
  17. Remove lower dipstick tube. Ive tried but its getting hung up on the bracket.near the top of the ball housing. But its love and has give so should be ok.Attach transmission jack to transmission and remove remaining engine to transmission bolts. Lower transmission and remove from below vehicle. Use caution not to damage right side catalytic converter when removing transmission
So all that is left is the torque converter bolts...3? And then the bell housing bolts (ive counted 7 including the 12 point starter bolt but ive read there 8 or 6 of them. I'm gonna look but I can't seem to see any more. )
Thats is all for today
  #694
Old 07-01-2020, 03:22 PM
Rescue119's Avatar
Duplicate post
  #695
Old 07-01-2020, 03:38 PM
JayJagJay's Avatar
Received 1,296 Likes on 897 Posts
Rescue,
THX!!
It IS a great thread, ain't it tho! Can't wait for the trans work. Is in my future no matter what,,, am thinking about the T700
About the covers. They will/can end up rubbing on things, come undone or partially, flop around. And they are quite old at this point. I was told by a resident GURU here, that it is FINE to leave them off. I chucked mine. Happily.
  #696
Old 07-01-2020, 04:49 PM
Glad to hear. Mine are going in the trash.
thanks all.
The following 2 users liked this post by ChrisHarley2008:
Greg in France (07-02-2020), Rescue119 (07-02-2020)
  #697
Old 07-02-2020, 08:43 AM
Rescue119's Avatar
Working today and not busy so searching kijiji.
Found a cheap getrag 260 manual transmission... would.it work? Lol
  #698
Old 07-02-2020, 08:48 AM
Not strong enough.
  #699
Old 07-02-2020, 09:08 AM
Rescue119's Avatar
Not strong enough.
Ya i heard its the weaker of the 2 , 265 being the other.
there is a 265 also but its 3 times the price
  #700
Old 07-02-2020, 09:47 AM
Rescue119's Avatar
Hey Greg,
since I am taking out the transmission should I replace or upgrade the stall converter? New ones aren't expensive and since im gonna have it out anyways
If replace what stall? 2500? 2000?
Quick Reply: Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
