Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
#821
Brake buster (03-08-2021)
#822
So found the "block heater" as us Canucks call it. Most are in the block but not this one.
Orange piece is the element into the metal T which us spliced into the lower larger rad hose.
im gonna remove it. Looks.like a 1" wrench. Hoping I can drain the system from there. I'm replacing the hoses anyways so worse case I undo the hoses. I do not have a pet ****....
My wife does ....
Also
It's getting warmer
My wife does ....
Also
It's getting warmer
Dleit53 (03-11-2021)
#823
As im.putting my.shopping lists together what gasket should I get.
So far I have both valve cover gaskets and both thermostat gaskets. The oil pan was all ready done. I'm not removing the heads. I feel like there should be more.
Everything works in the engine ok but it just needs a good going over so I'll call it a soft refresh and tune.
also I want to remove all the emissions stuff. I believe the air pump is part fo this?
Did anyone make a how to on this. I'll keep googling but if you have a favorite link it please.
Trying to minimize the engine bay as best I can. Still undecided about removing the a/c or just service it.
I'm gonna budget about 2k cdn and so far I'm up to 700 in parts. But haven't sourced a fuel injector rebuild kit. V12 performance has one but I've heard stories that make me run away.
Speaking of injectors they should still be fin shouldn't they. One they are rebuilt? I don't need to get new injectors. I don't think I do. And I see long hose vs short hose. Anyone know the measurements on these so I know if I have long or short.
Thanks.in advance as always.
Glad to be back.
Glad to be back.
Greg in France (03-10-2021)
#824
Injectors will be fine from an actuating point of view, but they will need new rubbers and hoses, if these are the originals. Mr Injector makes a good kit all ready to fit.
https://mrinjectoruk.co.uk/Jaguar-V1...7-P298680.aspx
The injector harness may be old and cracking, if it is, you must, absolutely must make one or buy one. Also the thermostats will be best renewed, and any hoses not done. Apologies if you have already done all this earlier on in the thread!
Have you got the half-moon seals for the cam covers? or nice aluminium aftermarket ones to be smart?
#825
Never thought about the electrical harness. I havent really inspected it yet. So I'll keep that in mind.
Nope completely forgot about that little piece in the back so thank you again for the 100th time.
#826
That link says they are closed for the holidays and will reopen but maybe they didn't do to covid?
https://mrinjectoruk.co.uk/ContactUs.aspx
#827
Same with the aluminum half moons. I found one on ebay but doesn't have the rubber seal.
the one with the rubber seal is being hard to track down. I got time anyways. Just the 1 month shipping from UK for some items is a pita.
#828
Kirby recommends no gaskets for the cam covers? And I guess ill need intake gaskets as well. He also mentions to cut the intake gaskets up instead of laying in one piece. I have printed out your PDFs and haven't gotten that far yet but before I order stuff should I head Kirby advice or is it outdated?
#829
You need the gortex (ie genuine OEM) cam cover gaskets with a light dressing of this stuff each side:
https://www.gasgacinch.com/
This combo is the absolute bees knees, I used it on my diff cover and the diff is BONE dry, which is almost unheard of. The ally seals will be fine with RTV to seal them to the block. Or the rubber OEM ones ditto - which Grant 100% recommends, by the way.
What the Great Palm is right about is sourcing slightly longer cam cover fixing bolts and allen-key headed ones at that, and using wider washers and spring washers, as in this pic when i did mine. 100% oiltight for over 10 years. BUT, be careful to identify the threads on the OEM fixing bolts: they may be UNC or Metric, and the two look nearly identical
the other thing is the possible weep from the tappet block/head interface. This was not sealed from the factory, and can leak, in fact is the most likely leak-place, I believe. if you clean it up and sand the join area with coarse paper, then seal it with hi-temp RTV, it will hold leaks perfectly. And you can probably do it far more neatly than I did!
#830
#831
Greg in France (03-11-2021)
#833
#834
Rescue
Use the correct temperature thermostats! Take a look at this thread:
https://www.jaguarforums.com/forum/x...ywhere-213647/
944play (03-11-2021)
#835
#836
Rescue
Ordered thanks. thanks.
I just spent almost 1k on ording parts this morning lol
#837
#838
plus I should be promoted next year when I get posted and make a crazy tonne of my current house because the market is going insane here.
I told my wife with the money I'm getting this month I could just go buy a running Jag. The look I got was priceless
#839
#840
