Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old 04-07-2021, 08:03 PM
jag-reflex's Avatar
Originally Posted by Rescue119
That picture is with the pedestal out lol. So it's just a matter of getting the wrench on the sender and sensor and removing them then?
Also I read elsewhere that I should replace the washers for the oil banjos that are behind the heads (once I take the cam covers off) as they leak. I'll probably post.about that later on anyways.
yep, pedestal (I'm talking about the block holding the sender/sensor, so remove banjo, then 2 bolts) in vise, wrench on the nuts and out. I replaced all the copper washers on the banjos. The ones behind the heads are zero laughs.
  #942
Old 04-08-2021, 04:48 PM
Rescue119's Avatar
ok thanks
  #943
Old 05-25-2021, 04:40 PM
Rescue119's Avatar
Still alive. Got home last week and spent a week getting caught up on honey do list.
Starting to get back into the car. Still just wiping all the build up of oil. Hopefully start putting some things back together before I forget how it all was lol.
I've decided I'm gonna leave the a/c in place and once I get the car running I'll tackle it. It's kinda works and ya it's in the way but it doesn't effect anything so I'll work around it.
Greg in France (05-26-2021)
  #944
Old 05-26-2021, 06:00 AM
Rescue119's Avatar
So I was reading one of the pdfs and it suggested to take the top plate of the V out to reseal it. I have removed everything from the V now except the a/c compressor which is attached to the V by 2 bolts and a bracket.
Should I remove it while I'm there?
Whats exposed if I do?
I'm unsure if it leaks oil just because it has over 30 years off grim built up in the V so can't tell in that area.
  #945
Old 05-26-2021, 07:49 AM
Greg in France's Avatar
Received 9,413 Likes on 5,516 Posts
Leave it alone. Just clean the V with white spirit/brake cleaner etc, replace the oil pressure senders, do the cam covers, all will be well.
  #946
Old 05-26-2021, 09:14 AM
Rescue119's Avatar
ok thanks. Got 1/2 cleaned now onto the other half.
system.just using wd40 decreased first. It's the bio friendly one so not super strong. Just to get the main stuff then I'll give it a once over with better stuff once I'm ready to start reinstalling.
But just doing that the engine already looks better. it's exciting.
Bez74 (06-03-2021)
  #947
Old 06-02-2021, 06:06 PM
Rescue119's Avatar
Well I've gotten most of the 30 years of crud build up out of the V.
So now it's time to start on removing the valve covers.
after I remove them I'll give them a good cleaning and repaint. Then all that's left to remove is the dizzy cap and spark plugs and then I can start putting this beast back together. Hopefully I didn't forget how lol.
Forgot to mention also changed the rear brakes on a 2016 Mercedes gle350D this morning for a nieghbour. Didn't know they didn't have stud on the wheels (lugs/studs are all one piece) makes it a pain putting wheel back on lol.
Oh well.made 100 bucks and a 30 pack of bud lol.
  #948
Old 06-03-2021, 12:34 AM
Nice work, Rescue. Cleaning the V was by far the worst job I had to do on my rebuild.
  #949
Old 06-03-2021, 04:17 AM
Dukejag's Avatar
Rescue - ever come to NZ - i have a small job to keep you occupied for a week.
Will provide a pillow and meal...
But what a job looks great, really enjoying your rebuild, you might even be quicker than a week after this practice...
keep the updates coming!
  #950
Old 06-03-2021, 04:50 AM
Rescue119's Avatar
Yes I thought the rear end was worse but this has now taken the spot. Just so many nook and crannies.
At one point I contemplated hold my 3 year old by his feet and dangle him over it so he could get his tiny hands....but the wife stopped me lol
  #951
Old 06-03-2021, 04:51 AM
Rescue119's Avatar
Would love to visit. Always wanted to go there.
  #952
Old 06-03-2021, 12:42 PM
JayJagJay's Avatar
Received 1,296 Likes on 897 Posts
Mineral spirits/thinner and a good long bristled paint brush,,, then some good warm water and strong soap... Plugs in, duct tape over intakes. Rip and roar... That's just me...
I'd removed the AC unit for this stage of things and glad I did. Jus say'n...
  #953
Old 06-05-2021, 11:21 AM
Rescue119's Avatar
I removed the 4 mounting bolts for the a/c today. To make it easier to get the front 2 plugs out. So little more cleaned now lol
  #954
Old 06-05-2021, 11:25 AM
Rescue119's Avatar
Plugs out, dizzy cap off
Plus we're gapped at .035. NGKs
  #955
Old 06-05-2021, 11:36 AM
Rescue
Plugs should be 25 thou, not 35. Plus they look like a new set is a good idea. That rotor looks horrible, so new one there too. If it were me, new cap too!
  #956
Old 06-05-2021, 11:39 AM
Rescue119's Avatar
Rescue
If its coming off the engine it's being replaced with new. Im glad I just bought everything new just in case.
Even though the blue cap would match the new blue plug wires.
Greg in France (06-05-2021)
  #957
Old 06-05-2021, 01:34 PM
JayJagJay's Avatar
​​​​​​It's ALLLLLL good, but you're getting into the good stuff now. I likes the engine work... Electrical,,, haha, I need my head checked - but I'm learning to feel much more comfortable with engine and mechanicals...
Good stuff Man!
  #958
Old 06-05-2021, 02:44 PM
Rescue119's Avatar
Good stuff Man!
Same. I so use to 4 bangers and v8s this is different but fun.
  #959
Old 06-06-2021, 11:04 AM
Rescue119's Avatar
Today's progress
All new plugs gapped to .025 and put in, oil sensors pedestal cleaned, new oil pressure switch and new oil warning light switch installed, new dizzy rotor installed.
Had to order new copper washers for the banjo bolt. Should be here tomorrow.
Work tomorrow but then should be off rest of week due to getting 2nd covid vaccine shot then being grounded.
Greg in France (06-06-2021)
  #960
Old 06-07-2021, 01:44 PM
Rescue119's Avatar
Finally got the value covers off.
Someone suggested I should measure the clearances. But not sure were. under the tappets? Idk
Also I think I remember reading somewhere about replacing the cover bolts with longer Allen heads? But can't find that info.
this is as far down as I'm going.
The following 2 users liked this post by Rescue119:
Dukejag (06-10-2021), Thorsen (06-09-2021)
Quick Reply: Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
