Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
#1001
#1002
#1003
#1004
I have to tap the holes the air rail feed into the intake next before I start putting stuff back in the V. Then next is the cruise control bellows and bracketbracket.once that's back in the V I can start working on Then intake manifolds and fuel injection system.
Greg in France (07-07-2021)
#1005
When I did mine, I tapped the holes to 5/16-18 and used screws like this with thread sealant to close off the ports.
It's best to do it when the manifold is off the engine. I would do it on the car if it was a do-or-die situation but since you have the manifolds off there's no better time like the present.
The following 2 users liked this post by Thorsen:
Dukejag (07-07-2021),
#1006
I've done one I'm just waiting for the screws to show up to make sure i have the right depth so I can mark my tap before I do the other 11.
The following 2 users liked this post by Rescue119:
#1007
#1008
#1009
#1010
So just redoing the cruise control bellows and I've read there's some silicone that needs to be applied to the inside lip.
When I took mine apart there was no sign of silicon being used. It was the orginal bellows.
So do I dry fit it or find some silicone for it?
my ref
https://www.jaguarforums.com/forum/xjs-x27-32/how-cruise-control-repair-120863/
my ref
#1011
Greg in France (07-10-2021),
Thorsen (07-10-2021)
#1012
The silicone is there to help contain the vacuum in the bellows, IF, repeat IF, the rubber of the beloows has hardened a touch and it will not, on its own, hold vac. If the CC works Ok without silicone, all good. If it does not apply silicone to help the bellows seal.
ptjs1 (07-10-2021)
#1013
#1014
The following 3 users liked this post by Rescue119:
#1015
The following 5 users liked this post by Rescue119:
Dukejag (07-12-2021),
eurolat (07-11-2021),
Greg in France (07-11-2021),
ptjs1 (07-11-2021),
#1016
#1017
#1018
Greg in France (07-13-2021),
ptjs1 (07-13-2021)
#1019
#1020
