Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old 07-06-2021, 07:13 PM
Xjeffs's Avatar
Default Next
Originally Posted by Rescue119
After
that looks great. I just sent you mine.
  #1002
Old 07-07-2021, 01:57 AM
Dukejag's Avatar
Yep - looks real good, this is the fun part making things look new or better than new!
The plated parts that were gold can be replated very cheaply and will look new.
Whats next...
  #1003
Old 07-07-2021, 05:38 AM
Rescue119's Avatar
haha thanks
  #1004
Old 07-07-2021, 05:40 AM
Rescue119's Avatar
Whats next...
I have to tap the holes the air rail feed into the intake next before I start putting stuff back in the V. Then next is the cruise control bellows and bracketbracket.once that's back in the V I can start working on Then intake manifolds and fuel injection system.
Greg in France (07-07-2021)
  #1005
Old 07-07-2021, 06:46 AM
Thorsen's Avatar
Received 1,572 Likes on 677 Posts
When I did mine, I tapped the holes to 5/16-18 and used screws like this with thread sealant to close off the ports.
It's best to do it when the manifold is off the engine. I would do it on the car if it was a do-or-die situation but since you have the manifolds off there's no better time like the present.
The following 2 users liked this post by Thorsen:
Dukejag (07-07-2021), Greg in France (07-07-2021)
  #1006
Old 07-07-2021, 06:57 AM
Rescue119's Avatar
Yep exactly the size and screws I'm using and with the tread sealant.
I've done one I'm just waiting for the screws to show up to make sure i have the right depth so I can mark my tap before I do the other 11.
The following 2 users liked this post by Rescue119:
  #1007
Old 07-08-2021, 02:54 PM
Rescue119's Avatar
Switch came in. Put the new coil on. Ready to go back into Vee
  #1008
Old 07-08-2021, 09:48 PM
89 Jacobra's Avatar
Received 1,198 Likes on 694 Posts
Looks good for another Hundred Thousand Miles.
Jack
  #1009
Old 07-09-2021, 08:20 AM
Rescue119's Avatar
Jack
I dont think I've every owned a car long enough to out 100k on it lol. I think my minivan will be the first but I still got 60k to go.
plan is to have it for my sons 16th birthday in 13 years time.
  #1010
Old 07-09-2021, 12:24 PM
Rescue119's Avatar
So just redoing the cruise control bellows and I've read there's some silicone that needs to be applied to the inside lip.
When I took mine apart there was no sign of silicon being used. It was the orginal bellows.
So do I dry fit it or find some silicone for it?
my ref
https://www.jaguarforums.com/forum/xjs-x27-32/how-cruise-control-repair-120863/
  #1011
Old 07-09-2021, 10:46 PM
Rescue119's Avatar
My grub screws showed up. Got one in. Worked great. So now to do the other 11 lol.
Greg in France (07-10-2021), Thorsen (07-10-2021)
  #1012
Old 07-10-2021, 01:22 AM
Greg in France's Avatar
Received 9,413 Likes on 5,516 Posts
The silicone is there to help contain the vacuum in the bellows, IF, repeat IF, the rubber of the beloows has hardened a touch and it will not, on its own, hold vac. If the CC works Ok without silicone, all good. If it does not apply silicone to help the bellows seal.
ptjs1 (07-10-2021)
  #1013
Old 07-10-2021, 06:24 AM
Rescue119's Avatar
Ok thanks. It's a new bellows so it's flexible. The old one was definitely not.
  #1014
Old 07-10-2021, 01:53 PM
Rescue119's Avatar
Bellows on, set screws in,
Recounted the a/c compressor
The following 3 users liked this post by Rescue119:
Doug (07-11-2021), Greg in France (07-10-2021), Thorsen (07-10-2021)
  #1015
Old 07-10-2021, 06:11 PM
Rescue119's Avatar
The Vee getting full again lol
Now onto this mess
The following 5 users liked this post by Rescue119:
Dukejag (07-12-2021), eurolat (07-11-2021), Greg in France (07-11-2021), ptjs1 (07-11-2021), Thorsen (07-10-2021)
  #1016
Old 07-12-2021, 03:45 AM
Dukejag's Avatar
Have you converted to a single coil?
  #1017
Old 07-12-2021, 04:37 AM
Rescue119's Avatar
Well i couldn't find the 2nd coil even though I had the round one but yes I have the square one now as recommended. Scroll up and you will see it.
  #1018
Old 07-12-2021, 06:45 PM
Rescue119's Avatar
Just about finished the FI harness. I promise it will look neat once it's installed lol.
Greg in France (07-13-2021), ptjs1 (07-13-2021)
  #1019
Old 07-13-2021, 01:38 AM
It should be on the apron in front of the radiator grille.
  #1020
Old 07-13-2021, 01:40 AM
Dukejag's Avatar
Holly molly - that is some good work.
What / how did you do that?
Is there a nice simple drawing us simple men can follow?
Next winter... love to build one.
Quick Reply: Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
