Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old 10-26-2021, 04:54 PM
Thorsen's Avatar
Received 1,553 Likes on 669 Posts
Welcome to the club! Which engine did you go with?
Not sure where you live but if it's somewhere that gets a real winter - those tires are criminal in the snow. I have a set of snow tires I'm going to throw on next month.
  #1102
Old 10-26-2021, 05:38 PM
Rescue119's Avatar
nice. I'm in south Ontario Canada so winter's are meh at best. Just drive slower and 4wd is fine. Never had an issue in 30 years of driving. Even ran a set of summers all winter once lol. Now that was fun.
The V6 with etorque. 3rd 3.6 v6 engine. It's tried and true. Plenty for this Jeep
  #1103
Old 10-26-2021, 05:47 PM
Thorsen's Avatar
You're going to have a blast - enjoy it!
  #1104
Old 11-03-2021, 04:32 PM
Rescue119's Avatar
Filly got the angle grinder onto this. Looks better and pretty solid. So I'll clean it up, give it a shot of paint and reuse
Greg in France (11-04-2021)
  #1105
Old 11-07-2021, 11:12 AM
Rescue119's Avatar
So this is finished
The following 2 users liked this post by Rescue119:
Dukejag (11-09-2021), Greg in France (11-07-2021)
  #1106
Old 11-07-2021, 11:19 AM
Rescue119's Avatar
So when taking off the thermostat housings. Driver side was fine....
But the passenger side didn't go as well.
The 2 bottom bolts? Studs? Idk. Top left one was a stud, top right one was a bolt so I dont know what these 2 are. Bolts I think.
Anyways they snapped off as soon as I wrenched on them. I had sprayed the previously a few times as well. Only was using a 1/4 ratchet too.
So this is where I'm at
I dont mind drilling and tapping but I can't get a drill in there.
It looks like that housing can come off... 4 bolts or studs...can it come off?
So I sprayed them and gave the first one a little try and it felt really tight so I stopped. I'll try again tomorrow after it soaks for awhile.
  #1107
Old 11-08-2021, 01:12 AM
Greg in France's Avatar
Received 9,331 Likes on 5,475 Posts
The housing is all part of the water manifold, and to get that off can open Pandora's box, as the manifold fixing bolts also sheer off very easily. Ben Kenobi has recent experience of this!
I had exactly the same trouble a few years ago. From memory, some are bolts and some are studs! It does not matter which sort you use to replace them, but use stainless. I happened to have this sort of drill:
Amazon Amazon
which I seem to remember I used.
  #1108
Old 11-08-2021, 04:55 AM
Rescue119's Avatar
https://www.amazon.com/Bare-Tool-Mil...L&ts_id=552806
Ok thanks for the tip about the water manifold. I've gone down the rabbit hole long enough lol.
I could always use a new tool lol
Greg in France (11-08-2021)
  #1109
Old 11-09-2021, 05:12 PM
Rescue119's Avatar
Fixed using this attachment for my drill I bought.
Retapped to 6mm. Need to resize the bolts
The following 4 users liked this post by Rescue119:
Doug (11-13-2021), Dukejag (11-15-2021), Greg in France (11-10-2021), Thorsen (11-09-2021)
  #1110
Old 11-12-2021, 01:41 PM
Rescue119's Avatar
Little more puttering
Cleaned and painted the thermostat housings.
Removed the clutch fan housing and idler
Cleaned up the front my using a scraper to get the Ole gunk off. I'll keep at it while I have the room
Also drilled the 2 small holes in the new thermostats. No pic.
The following 3 users liked this post by Rescue119:
Greg in France (11-13-2021), ptjs1 (11-12-2021), Thorsen (11-12-2021)
  #1111
Old 11-13-2021, 02:28 AM
Rescue, while you are in there, check theintegrity of the rubber plug, A bank front, just above the water pump casting crescent part. Always leak because the rubber gets cooked in no time. Nice ally plugs are available and are really worth having:
https://www.ebay.co.uk/itm/324493991...IAAOSwXGxgMnfY
This is mine, bought years ago from the USA, very nice guy now deceased sadly Just fit and forget:
  #1112
Old 11-13-2021, 07:56 AM
Rescue119's Avatar
This spot?
Was pretty dry around there. But I'll take a closer look today when I do more cleaning.
Also if I pull the old one out will oil come out. I didn't drain the oil for my rebuild.
  #1113
Old 11-13-2021, 10:40 AM
Yes, the place you indicated. No oil will come out when you remove it, and do not worry if pieces drop inside; no harm will come.
Rescue119 (11-13-2021)
  #1114
Old 11-13-2021, 11:56 AM
Rescue119's Avatar
Thanks I'm just cleaning still. Ugh I do more cleaning of 30 year old gunk then rebuilding lol
  #1115
Old 11-13-2021, 02:00 PM
Rescue119's Avatar
More cleaning done. 3 cans of brake cleaner and a bunch of scrubbing lol.
I think ill stop here. Much better then before and I don't need it to be showroom condition. At least I can see the bolt heads now
The following 5 users liked this post by Rescue119:
944play (11-13-2021), Dukejag (11-15-2021), Greg in France (11-13-2021), JayJagJay (11-15-2021), Thorsen (11-14-2021)
  #1116
Old 11-14-2021, 01:09 PM
Rescue119's Avatar
Here is what the plug looks like
  #1117
Old 11-14-2021, 01:31 PM
It looks fine. If you do not change it, make sure you keep an eye on it, as once you start using the car it will leak.
Rescue119 (11-14-2021)
  #1118
Old 11-15-2021, 10:38 AM
JayJagJay's Avatar
Received 1,296 Likes on 897 Posts
damn jealous over here!
  #1119
Old 11-15-2021, 03:45 PM
Rescue119's Avatar
Lol thanks.
  #1120
Old 12-14-2021, 06:56 PM
Rescue119's Avatar
Hi all.
got called away very quickly for work. Was gon 17th Nov to Dec 8th. and found out today we are back to work from home state til Jan 10th. So I have some time to work on the Jag now.
I got the rad mounts in the mail as well as the plug for the block while I was gone.
I've been debating about the water pump. I didnt see an issue with but now that I'm staring at it on the engine I'm debating on touching it. Lol. But it's not really in a bad spot if it fails down the road and I think I've touched enough stuff.
I did read about someone replace the water pump with an electric one which interested me.
Anyways I'm gonna take my radiator to a shop tomorrow and see how much to refurb it.
In regards to that is there anything that's super special about the rad. It's a business that's been around for 30 years so I would hope they have done one xjs / xj rad lol. I have a price in mind that will be acceptable. I've also priced after market so I know when to say refurb or not.
Greg in France (12-14-2021)
Quick Reply: Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
