Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old 05-30-2022, 02:29 PM
Rescue119's Avatar
Rescue
FYI alternators have what is caled a "clock face", the first one you had was for a fitment with the face for mounting on the other side (assuming bottom fulcrum and top adjuster).
Ya. Was worth a shot lol.
  #1162
Old 05-30-2022, 06:09 PM
Rescue119's Avatar
Ok trying to figure out alternator wiring.
So there's 3 wires.
One goes to the starter.
Two goes to a small black box on the RHS fender (load dump module?)
Three goes up the RHS fender then disappears towards the bus bar?
So my picture I drew shows the orginal wiring. Wire one is obvious. 2 and 3 where wired to the same post on the back of the stock 120amp alt.
My new to me cs 130 alt has one post (battery) and a plug with 4 wire as show above.
The alt shop said take the S (sense wire) and run it to the battery post on the back of the alt where #1 wire would go.
The L wire is for the gauge etc.
Ok now this is where I get a little confused. I could wire 2 & 3 to L and 1 to the post on the back with S wire.
But reading this post he suggest to run the S wire to the bus bar? I think he has an older XJS so something us different. Here's a screen shot of his comment and then some other shots of wire.
Factory manual #1 is starter # 77 is battery
Another pic I found online irt xjs alternator wiring
So which way do I go? Also where exactly is the bus bar? Is it the fuse holder of the upper back side of the RHs fender? Under a plastic cap?
Cheers. I hate auto electronic stuff.
  #1163
Old 05-30-2022, 06:14 PM
Thorsen's Avatar
Received 1,553 Likes on 669 Posts
Just cut and tape off the wires for F and P. You don't need them.
You do need the S as it tells the alternator what the charge level of the battery is. You can either connect it to the the big lug on the back of the alternator, the bus bar, or to the battery directly. All it does it sense battery voltage. I've been connecting them to the lug on the alternator for years and they work perfectly.
The L goes to the light in the dash. If you don't connect that the alternator won't charge.
Greg in France (05-31-2022)
  #1164
Old 05-30-2022, 06:16 PM
Rescue119's Avatar
Which wire of 2 and 3 go to L? Or do both?
  #1165
Old 05-30-2022, 06:51 PM
Thorsen's Avatar
The bus bar is on the firewall. If you follow the big cable from the starter it connects to the bus bar on the firewall. There's also a wire running back to the positive terminal on the battery. All the +12 volt feeds come off the bus bars - there is one on each side.
If wire #2 is the one that goes to the dump module - you can pull the dump module. You don't need it with the CS-130.
Is wire #3 a brown wire with a blue tracer? On my '89 that was the wire that went to the alternator dash light. If so, #3 connects to the L(ight) terminal on the alternator. If you send me a link for your wiring diagram I can help you find it.
At the end you should have 3 wires on the alternator. The big heavy one connects to the lug on the alternator. The S(sense) wire also connects to the big lug on the alternator. The L(ight) wire connects to the wire that goes to the instrument cluster.
The following 2 users liked this post by Thorsen:
Greg in France (05-31-2022), ptjs1 (05-31-2022)
  #1166
Old 05-30-2022, 07:07 PM
Rescue119's Avatar
Yes brown wire #3. #2 goes to the dump module
Thanks for the help
  #1167
Old 05-31-2022, 11:59 AM
Rescue119's Avatar
Finished connecting the FI loom to the main plug.
Still gotta tighten it down but it's done
  #1168
Old 05-31-2022, 12:01 PM
Rescue119's Avatar
Is this how the bottom mounts for the rad sit? I don't recall and mine were destroyed.
  #1169
Old 05-31-2022, 12:13 PM
Greg in France's Avatar
Received 9,331 Likes on 5,475 Posts
Yes, and the prongs on the radiator bottom go into the rubber bungs.
  #1170
Old 05-31-2022, 12:32 PM
Rescue119's Avatar
Ok thought so.
One more thing I touched up today
Also I went to rad shop. They don't do custom fab but I got a name of a person who does. So I'm going to get a shroud built to match the factory size and then I'll put 2 e fans in it.
I did find some aussie ones from the falcon but they wouldnt ship to Canada
Done for the day.
Got a guitar delivered (I'm just startingl so I'm gonna cool off and play with that lol
Back to work tomorrow but I have made great progress last few days.
Greg in France (06-01-2022)
  #1171
Old 05-31-2022, 01:18 PM
Thorsen's Avatar
Is that a new receiver/drier that you painted or are you re-using the original one?
  #1172
Old 05-31-2022, 02:54 PM
Rescue119's Avatar
Orginal. The a/c worked when I tested it. Not well but needs a recharge. And I found a local who has r12 still lol.
  #1173
Old 05-31-2022, 02:58 PM
Thorsen's Avatar
I would suggest replacing it. The desiccant inside the drier loses it's ability to absorb moisture over time - that's why you should replace the drier each time you open the system. If the dryer can't absorb any residual moisture in the system it rots the entire system from the inside out.
New ones are very reasonably priced.
Greg in France (06-01-2022), LnrB (06-01-2022)
  #1174
Old 05-31-2022, 07:11 PM
Rescue119's Avatar
I'll look at doing that when/if I get the a/c serviced.
  #1175
Old 05-31-2022, 07:13 PM
Rescue119's Avatar
Put the rad in.
I'll pick at getting hoses on. I think I can attach all the hoses next in step. I'll have to scroll back in my posts to find the disassemble list lkl
  #1176
Old 05-31-2022, 08:19 PM
Rescue119's Avatar
I think 2 of these a custom shroud should work great. 2 x 12"
https://www.spalusa.com/products/fan...2ffans%2f12%2f
Thoughts?
  #1177
Old 05-31-2022, 08:29 PM
Thorsen's Avatar
According to Spal the 12" fan does 1,350 CFM @ 13.5 amps.
The 13" fans that come with the Wizard Cooling radiator setup do 1,710 CFM @ 18.5 amps.
I'm big into overkill but the 12" fans should be perfectly fine.
File Type: pdf
File Type: pdf
  #1178
Old 06-01-2022, 02:21 AM
I do not think 2 x12 inchers will be big enough. SPALs for sure, nothing else will do; but I have found that you need the big fan to draw about 25 amps (amp useage is a more reliable measure of real world cooling ability). You can squeeze in a 16 incher and a 12 incher. BUT controlling them is the key, what are you planning?
New dryer is essential by the way.
  #1179
Old 06-01-2022, 04:55 AM
Rescue119's Avatar
For control I was thinking (if possible) that for the 2 x 12s that they would be both on at half speed for normal running. Then one would be on full speed based on the water pump temp sensor and then the 2nd would go full speed with the a/c.
  #1180
Old 06-01-2022, 05:12 AM
BenKenobi's Avatar
Then you need a fan controller - I have yet to find a satisfactory off the shelf item. I built my own variable speed and sequencer using an Arduino the goal being soft start and load based sequence and speed, I have bench tested and it works though I've not tested it in anger yet so I'm sure theres more to learn - I have a 15 and a 12. The fans are Comex which I'm sure will raise an eyebrow or two.
Quick Reply: Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
