Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old 09-10-2022, 05:25 PM
Rescue119's Avatar
So the xjs he took it of was originally a California car. He took it off 15 years ago and he said it was a mid 80s xjs.
Also the spoiler has the hole for the antenna roughed in. What I mean is the hole detent is there but it's not open.
  #1422
Old 09-10-2022, 09:03 PM
Mguar's Avatar
The best way to save that would be to do a rude and crude patch job. Than use those parts as patterns to make fresh molds.
It’s not hard. Nor should it be messy or terribly expensive. With experiance you should be able to repair a piece and make a mold every day until the whole set is duplicated. Use cheap chopped Matt to make the mold. However for the actual parts use cloth or get fancy and use Kevlar/carbon fiber. ( that will more than double the costs but dramatically add to the strength and durability ).
There are plenty of U tube video’s showing how. Or you could find a local to either show you how or simply do it for you.
Notice I said local. Shipping parts even light fiberglass parts around is expensive, not because of weight but because of the boxing requirement.
  #1423
Old 09-10-2022, 09:11 PM
89 Jacobra's Avatar
Received 1,188 Likes on 689 Posts
Being Fiberglass it can definitely be repaired as it was simply a resin and glass matt, or strands. the "Mold" would be nice as that makes it easier, to get things back to what they were, but it is not absolutely necessary. Use cardboard to fill in, and create the contour for the missing pieces, to the general shape, and then glass over it. If it's not in a critical or visible area you can leave the cardboard in place. Looks to be a fairly nice design. Hope it helps.
Jack
  #1424
Old 09-11-2022, 01:33 AM
Mguar's Avatar
Yes you can repair it that way but it will always be a weaker area.
For cosmetic reasons only you can probably get by, but to retain a percentage of strength, you will need to spread the repair out because the joint will not be very strong.
Access to the back side will allow the added mass required to regain a percentage of strength to be hidden.
If you’ve ever experienced a major body failure at the speed Jaguars are capable of you’ll understand my concern.
LnrB (09-11-2022)
  #1425
Old 09-11-2022, 05:47 PM
Rescue119's Avatar
I had some reinforcement tape I use to use for r/c bodies so taped the broken piece up to the rest of the rear.
Here's what it would look like together and in the right orientation
  #1426
Old 09-12-2022, 04:09 AM
Shaneb's Avatar
Looks like the condition I got an xjs lister body kit in many years ago off a wrecked car, took a fair bit of bit to patch up. Pics from 2005 and of recent, generally most days still like the look of the kit.
  #1427
Old 09-12-2022, 08:32 AM
Rescue119's Avatar
Awesome. Thanks for the pics. I don't have the front piece though.
  #1428
Old 09-12-2022, 08:34 AM
Rescue119's Avatar
If you have any pictures of how its mounted please post them. Most of the holes are busted. It will be a next spring project
  #1429
Old 09-12-2022, 09:52 AM
ptjs1's Avatar
Received 3,096 Likes on 2,043 Posts
Rescue,
I stand corrected! Now that I see that the bumper was upside down in the first pic, it could be from a Lister kit. The Hyper rear bumper is also similar, but I recall had cutouts for rear fogs next to the exhaust pipes.
Paul
  #1430
Old 09-12-2022, 03:47 PM
Rescue119's Avatar
Originally Posted by ptjs1
Rescue,
Paul
i think those 2 round holes are for where the rear bumper supports pass through looking at other pictures i found online..
  #1431
Old 09-12-2022, 08:57 PM
Rescue119's Avatar
Do you have a pic of the finished rear? Straight on
  #1432
Old 09-13-2022, 12:14 AM
Greg in France's Avatar
Received 9,331 Likes on 5,475 Posts
Correct, they are.
  #1433
Old 09-13-2022, 02:41 PM
Rescue119's Avatar
Correct, they are.
you will also note the fade paint in that area where the inside of the bumper would have been slightly rubbing during its time mounted
  #1434
Old 09-13-2022, 09:29 PM
Rescue119's Avatar
Was the orginal rear bumper a 3 piece? Cause it looks like someone tried to make it a one piece at some point
  #1435
Old 09-16-2022, 11:50 AM
Rescue119's Avatar
my quickjack showed up this morning so hopefully i can get that together this weekend. Im away sunday to sunday though.
  #1436
Old 09-16-2022, 09:29 PM
Rescue119's Avatar
Pic of boxes. I got all the accessories as well so I can use it for multiple vehicle types etc and it's the one rated for 7000lbs
I got this light from quickjack as well.
It's pretty sweet and bright. Different ways to mount it as well
LnrB (09-17-2022)
  #1437
Old 09-16-2022, 09:44 PM
89 Jacobra's Avatar
That Lite Stix looks pretty Cool. I think I've seen it by other manufactures as well, I didn't know Bend Pak even made them. Looks like a damn nice light.
Jack
  #1438
Old 09-17-2022, 01:44 AM
Shaneb's Avatar
Rear skirt is three piece so you must be joined, attached are some pics from rear. If you want to know more on how it is fastened let me know
LnrB (09-17-2022)
  #1439
Old 09-18-2022, 09:55 PM
Rescue119's Avatar
Awesome! Thank you so much.
I plan on shaving the rear bumper off when I get to yhe body phase of my project. I think ill make it a one piece though.
How come u have red lights in your rear bumper?
  #1440
Old 09-19-2022, 03:28 AM
ptjs1's Avatar
Most markets have the lights in the bumper. Perhaps only North America didn't because of the paranoia over crash protection?
Paul
Quick Reply: Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
