Rewire advice distributor to ignition amplifier
l have the failing wiring between the Distributor and ignition amplifier on my 1982 V12 HE.
l want to rewire that section, is there a advised method? lm thinking i will eliminate that one connector block, but thats about it.
ls there any advised maintenance to carry out in that area ''while im there''?
Cheers AOI
Cheers AOI
That is tricky.
The wires inside the distributor need to be retained, due to the "flexibility" of them for the movement of the vac capsule on the base plate. Copper wire will fail from the constant bending movement.
Soldering new to that "flexible" wire is doable, but takes time.
I eliminated the grommet on all mine, and when the new wires were done, filled the hole with Black RTV, in small layers, allowing drying time between, until it looked OK to me.
I believe some have renewed the wires all the way to the reluctor coil, I decided not to at the time, as the breaks were all inside that rubber grommet.
Doug (09-17-2019)
Received 10,979 Likes
Grant Francis (09-17-2019)
