Ride Height
gregh (11-06-2012)
The car should have a slight nose down profile looked at from the side.
FYI, the front ride height is adjusted by removing/adding large round spacers (the same diameter as the springs) from the spring pans. The spring has to be removed to make this adjustment, which is a fairly big job needing special tools and great care.
gregh (11-07-2012)
