right and left bank air intake
Just noticed on the right bank(passenger side) air intake, i cannot feel the suction. I held a piece of paper to the left intake and could notice the suction but not on the right. im baffeled should'nt both sides have substancial suction??? Note*(Just replaced alternator, and radiator)
Received 10,873 Likes
Qgregg (05-18-2012)
I believe its a timing reference hole, so that you dont have to take the cap off to see where the rotor is pointing. the vacuum hose sticks out of the side of the metal diaphragm, underneath the distributor cap, and is pointing towards your 6a spark plug
ok heres what i see, underneath the dist cap pointing towards the windshield is a white piece of plastic sticking out as if a hose should be covering it, now the loose hose also has a white plastic fitting coming off of it. im not sure if there was a little piece of hose in between to fit the two together or not i dont see any piece of hose down in there.
That the distributor vent hose.
There should be two small hoses to the distributor. One goes to the AAV hose to provide a small amount of vacuum. The other goes over towards the left fender and has a small air filter attached....looks like a small fuel filter.
Anyhow, the vacuum draws filtered air into and through the distributor for venting
