Rims Question
Fellas, I am looking into these wheels. I was considering the 18" rims. These are the specs that the guys gave me. Would these fit properly on my 95 xjs? Also, would a 19" fit? Also, what type of rotors would look nice with the rims? Any drilled ones that you would recommend?
COVENTRY WHITLEY 18x85 5120.65 ET20 CB 73.9 HYPER SILVER W/MIRROR CUT LIP ALLOY WHEELS
Vehicle: 1995 JAGUAR XJS
Bolt Pattern: 5x4.75 5x120.7
Hub Size: 73.9
Lug Nut: 1/2
Lug Type: NUT
Offset Type: MID
Offset MM: 15-25
RIM SPECS
Hub Size: 73.9
Lug Nut: 1/2
Lug Type: NUT
Offset Type: MID
Offset MM: 15-25
RIM SPECS
Is the manufacturer Coventry West? They should know the fitment. I think their wheels are made specifically for Jaguar vehicles.
A casual look suggests that they might not fit. I know a 17x8.0" wheel with 30-33* offset does fit. An 8.5" wheel is going to move the tire .25" closer to the fender/quarter lip, and going down in offset is going to move it out another .25". I think the total of .50" will be too much and your tire will rub.
I am not 100% sure about this. Maybe someone else could chime in.
lickahotskillet
10-18-2015 09:51 AM
lickahotskillet
09-11-2015 07:54 PM
