rims will they fit
Old 12-13-2016, 09:17 AM
revski666's Avatar
Default rims will they fit
hey guys will jaguar xk8 rims fit my 1992 xjs v12 here is the rim size 2002 JAGUAR XK8 FACTORY OEM WHEELS RIMS 18 X 8, 18 X 9
i seen them on ebay for $600 for the set is this a good price?
Old 12-13-2016, 03:10 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
Depends on the offset.
8" will fit on the front with 20mm offset
9" will fit on the rear with IIRC 35mm offset
orangeblossom (12-13-2016)
Old 12-13-2016, 06:09 PM
Jagboi64's Avatar
Received 3,184 Likes on 2,101 Posts
Other thing to consider is the design of the suspension isn't designed for rims that tall, the car will have a much greater tendency to tramline, or follow the grooves and ruts in the road than with smaller rims. 16" is generally considered as tall as you want to go to avoid that effect.
Old 12-13-2016, 08:50 PM
warrjon's Avatar
My car tramlines with 245-50/16, I do think the 16" look good on the car.
Old 12-14-2016, 01:20 AM
Jagboi64's Avatar
I'm running factory rims on my 94, but using 225-60/16. I think the taller and narrower tire helps avoid tramlining.
I really like the look of the later 5 spoke 16" rims.
Old 12-14-2016, 03:23 PM
warrjon's Avatar
Yes the narrower tyres will have less tendency to tramline.
My rims are 16X8 BBS originally for an XJ40 with +33 offset. It is illegal in Australia to use any type of spacer (unless it was manufacturer fitted) To change the offset of the front rims I had a 13mm spacer machined and fixed into the back of the rim with CS screws, thus becoming part of the rim. This is a much safer way than 13mm spacers, and at 20mm offset my front tyres do not rub even on full lock.
