Rough acceleration just returned from shop
Old 05-16-2021, 12:17 PM
JD3711's Avatar
Default Rough acceleration just returned from shop
Hello Everyone,
ive got a poser here. 94 4.0 2+2 135K miles. Going to work, started losing power. I shut it down. Had it taken to shop. They replaced distributor rotor; ignition coil; distributor cap; CPS; valve cover gasket; changed oil. Ran ok, but after a couple of days, it died again, they determined coil was bad, warranty replacement made. Ran ok then threw a FF14. I replaced the coolant temperature sensor. Ran better, fault was gone, but just this morning, it started missing again, and rough on acceleration but ok on idle. I didn’t replace the sender next to the CTS. Any ideas given the history so far?
Old 05-16-2021, 12:29 PM
Vee's Avatar
Vee
Vee is offline
Received 1,589 Likes on 1,234 Posts
Take a look at the harness wires at the CTS. There have been reports that the wires start to touch one another? Look for cracked insulation, or wobbly connection points?
How old is the fuel filter? Spark plugs (I assume the shop checked these)?
After that, I’d pull the ECU harnesses off and check for any corroded pins. This is a common problem. The ECU is in the passenger footwell.
Old 05-16-2021, 12:33 PM
JD3711's Avatar
thank you! Will check!
Old 05-16-2021, 02:51 PM
JD3711's Avatar
The wiring appears to be intact and well-wrapped. No melted areas, and the harness appears safe behind the guard next to the engine.
I’m not sure of the fuel filter’s age.
mom going to access the ECU to check for corrosion next.
Old 05-16-2021, 05:01 PM
JD3711's Avatar
I’ve accessed the ECU, per pics below. However, I’ve never seen actual plugs that look like this, so I’m nervous about trying to remove them, not really knowing what I’m doing. There are two long plugs, one yellow, and one blue. They have a “paddle” of sorts on one end each. I don’t know if I should push the paddle in, then try to wiggle the plug away from its mate, or pull the “paddle” away from plug and wiggle the plug out.
Here are the two ECU plugs I don’t know how to unplug.
Mkii250 (05-17-2021)
Old 05-16-2021, 09:27 PM
Vee's Avatar
Vee
Vee is offline
I apologize. I thought you had a similar ECU as the 95/96 models.
Im going to wait for another 94 MY owner, however, I now turn my attention to the fueling system. It would be great to get pressure readings from the fuel rail. That could shed some light on the state of your fueling system. Pump and/or filter? (The 95/96 MY do not allow for fuel pressure readings. There’s no valve to connect a gauge to, not sure if 94 has a way)
Please confirm last time spark plugs were replaced.
Old 05-16-2021, 09:32 PM
JD3711's Avatar
Default No sweat!
It’s a Lucas 15 CU as you can see.
Old 05-18-2021, 08:20 PM
Brewtech's Avatar
Id send it back to the shop. You paid to have things rectified and its not running any better. I know that it gets tiring but they shouldnt call you just because its been running good for 15 minutes.
Old 05-18-2021, 08:46 PM
JD3711's Avatar
Default Agreed.
Thank you, at this point before I go digging into unfamiliar ground, I believe I’ll do just that. I can repair only so much on my own, and the shop should do what they can do.
thank you much, and I will update the thread with any resolution successfully reached.
JD
Tulsa, OK
Old 05-19-2021, 05:32 AM
kansanbrit's Avatar
Losing power or missing, which describes it best? You have described the problem both ways.
Old 05-19-2021, 07:07 AM
Vee's Avatar
Vee
Vee is offline
Replacing the fuel filter is easy and replacing the spark plugs on these engines is even easier.
JD3711 (05-19-2021)
Old 05-19-2021, 07:55 AM
JD3711's Avatar
agteed. That’s an easy one I can do.👍
Old 05-19-2021, 10:05 AM
Vee's Avatar
Vee
Vee is offline
The shop may continue to search for the problem, and at $100/hour, they will, but it'd be best to cross off as many things as possible before the meter starts.
Old 05-19-2021, 10:37 AM
JD3711's Avatar
It certainly does both. It acts as if it is going to stall, dropping RPM's and oil pressure, and the engine shakes, and its obvious it's missing by the uneven shaking of the engine itself, the motion, sound, etc. I love your ending tagline by the way.
JD3711's Avatar
Totally agree with that. I don't want to send them on a fishing expedition.
Old 05-19-2021, 02:02 PM
Vee's Avatar
Vee
Vee is offline
Make sure you use the right spark plug. Stick to the basics.
Champion RC9YC or NGK BKR6E
Don't use any platinum, iridium, etc plugs. The cheap copper ones work best.
JD3711 (05-19-2021)
Old 05-20-2021, 06:40 AM
orangeblossom's Avatar
Received 3,846 Likes on 2,663 Posts
Hi JD3711
Since we are down to Clutching at Straws, at least for the moment
As Plug Wires 5 and 6 are near enough the same length, it is not beyond the realms of possibility that out of sight behind the Plug Lead Cover Plug Wires 5 and 6 may have somehow got misplaced so what looks like Plug Lead 5 is really Plug Lead 6 and visa versa
Definitely worth Checking that these two leads are going onto the right Spark Plugs
I know it sounds like a Long Shot but it has been known to happen also Plug Gap .025
JD3711 (05-20-2021)
Old 05-20-2021, 07:14 AM
ptjs1's Avatar
Received 3,156 Likes on 2,078 Posts
JD3711,
Just to clarify, does it always start fine, idle fine, and then misfire when you press the throttle?
Or does it start fine, idle fine, run fine, and then start to misfire after you've been running for a while?
PAul
Old 05-20-2021, 07:20 AM
JD3711's Avatar
Originally Posted by ptjs1
JD3711,
PAul
Exactly-number 2. It runs and operates great, starts great, then after it gets warmed up, it starts the stuttering a lot upon acceleration and you can also feel it missing,and you can give it a rev, and it gets better, but as it winds down, just starts that stuttering and missing shaking.
Old 05-20-2021, 07:23 AM
JD3711's Avatar
JD3711,
PAul
another thing: no codes are being thrown. I can’t understand that.
Quick Reply: Rough acceleration just returned from shop
