Rough acceleration just returned from shop
I’ve accessed the ECU, per pics below. However, I’ve never seen actual plugs that look like this, so I’m nervous about trying to remove them, not really knowing what I’m doing. There are two long plugs, one yellow, and one blue. They have a “paddle” of sorts on one end each. I don’t know if I should push the paddle in, then try to wiggle the plug away from its mate, or pull the “paddle” away from plug and wiggle the plug out.
Here are the two ECU plugs I don’t know how to unplug.
JD3711 (05-20-2021)
Exactly-number 2. It runs and operates great, starts great, then after it gets warmed up, it starts the stuttering a lot upon acceleration and you can also feel it missing,and you can give it a rev, and it gets better, but as it winds down, just starts that stuttering and missing shaking.
Does the tach flicker when its having a problem?
Mkii250
08-14-2014 04:34 PM
