rough idle and loss of power 1994 xjs 4.0
Old 02-26-2013 | 04:51 PM
Icarrya45's Avatar
Default rough idle and loss of power 1994 xjs 4.0
Hey guys, I'm a new Jaguar owner(father in law gave me 1994 xjs convertible 4.0 for my daughter). It has been sitting for 7 years. I cleaned injectors, replaced idle air control valve, cleaned plugs, new dist.cap and button, cleaned fuel tank, new fuel filter. Car idles very rough, i can hold rpms between 2000-4000 and runs fair. Put a load on it and it falls on its face. Thanks for any suggestions on my problem/s. code FF14
Old 02-26-2013 | 06:29 PM
Vee's Avatar
Vee
FF14 = Replace Coolant Sensor.
Icarrya45 (02-26-2013)
Old 06-26-2020 | 03:47 AM
Justin Barco's Avatar
Default I’m having same issue- did you find a solution?
Old 06-26-2020 | 10:55 AM
Vee's Avatar
Vee
Clean the throttle body, it is a must. Take it off the engine and give it a thorough cleaning. (assuming your same problem doesn't have a FF14 code as well?)
Old 06-26-2020 | 03:21 PM
XjsBanger's Avatar
Oops... You have AJ16 which is prone to timing chain strech. Especially if the car was sleeping for 7 years. Mind if I ask how you managed to start it up? Was it not started at least once over that time? There is a highly recommended start-up procedure for AJ6, AJ16 and applicable to any other engine...
Daniel Bar-Tal
09-08-2016 07:38 AM
93greenconv
07-27-2014 10:04 AM
Mad Matt
06-26-2014 05:29 AM
jomia092306
03-25-2014 06:46 PM
93greenconv
11-28-2013 12:30 PM
Quick Reply: rough idle and loss of power 1994 xjs 4.0
