Rubbing noise in rear
HI all,
think that I have narrowed my wheel rocking issue to the need for spacer(s). I was able to crawl under yesterday and take a close look. It appears that where the half shaft meets the differential has a bit of space between them. I have included pics. Will inserting a spacer do or is there some other adjustment?
Tony
Tony
If you have movement at wheel you need to trace back from there to determine if it in hub, uni joints or output shaft bearings.
Have somebody rock while you look, or better still feel (stick a finger across mating joints) to isolate the slack point.
So what I did was jack it up on that said. I crawled under it and got a girl next door to rock the tire in/out. The movement is at the top of the tire and only moves a very few degrees or CM/MM. From under, it looks like there is a sleeve that is sliding over some other shaft (for lack of a better explanation, like foreskin). The top pic is with tire free hanging and the second is with it pushed inward.
To clarify, there isn't a noise coming from this side. I am back to the hand brake not fully releasing that's causing the slight drag on the other side. Other hand the slight rock in the tire, it is great.
Tony
Tony
Tony
Tony
If you are hearing it l think the old bearings may be unserviceable anyway.
Tony
Tony
This post does not really read properly to me, I am afraid. But if you are saying that the two earlier posted photos are of the SAME driveshaft, one with the wheel pushed in and the other with it pushed out, then your diff output shaft bearings are shot for sure. Remember, it is ONLY the driveshafts that are keeping the rear wheels on. You have no alternative but to rebuild the diff, I highly doubt that with that amount of play, anything but a rebuild is worth doing. The good news is hat any diff rebuild place can do it, and kits of parts needed are readily available from (eg) Coventry West at around 250 USD from memory. As for taking it out, we can all explain how to do that yourself.
Greg
orangeblossom (04-25-2016)
The output shaft removal and rebuild will have no bearing on diff settings.
Workshop manual will cover it but short version disconnect inner halfshaft uni, remove bolts holding output shaft bearing housing and remove.
That unit then needs to be rebuilt using new bearings, collapsible spacer, nut, seal etc and bearing preload needs to be set via spacer crush. You do need the proper instructions for that.
Greg in France (04-26-2016)
#28
