Running Engine with Instrument Panel Removed
I have my instrument panel removed so I can do some heater core work. I had my core boiled out and pressure tested and I'm replacing the pipe o-rings with the white gaskets. I'd like to run the engine long enough to bring it up to temperature so I can check the pipe connections for leaks before I put the dash back together, but I don't want to damage something by not having a critical instrument circuit made. Has anyone tried this? Is it a bad idea? Thanks.
Received 10,873 Likes
twerth (02-09-2012)
rusty37
06-07-2016 04:43 PM
SingBlueSilver
08-27-2015 02:20 PM
