Running the v12 with no brake fluid in the system.
can I restart my v12 while the brake system has no fluid in it? Or will it damage the brake pump motor or anything like that? Obviously I’m not planning on driving it anywhere just going through the recommissioning process and first up is to get it running.many thanks
Hi Brinny
Don't even think about starting the engine unless you disarm the Brake Pump and the ABS or you will burn out the Brake Pump from which there is no way back
On a (UK) Car the Fuses are in a Compartment under the Passenger Knee Pad, which has a button that you can undo with a Coin
The 2 X 30 Amp Fuses for the ABS and the Brake Pump are behind this panel cover
Here they are 2 X 30 Amp Fuses for the ABS and the Brake Pump 'Pull Both of them out' before starting the Car or you will burn out the Brake Pump
Greg in France (01-03-2019)
cchong
10-28-2020 10:57 PM
orangeblossom
07-22-2015 08:40 AM
benebob
07-23-2010 03:40 PM
