Saturday April 27th Channel 4 (UK) TV Building the Legendary Jaguar XKSS
Greg in France (04-27-2019)
I cant tell you how unlikely that would be. Its hard enough to get her to go to classic shows in the summer. We have two shows to go to this sunday, one at Rickenhall and one at Bardwell. They should be quite good as they are small. We have been to the one at bardwell a couple of times before. a nice way to pass an hour or two and it keeps me out of the shed doing DIY
which is a blessing. Planting bloody plants today and I will have to cut the sodding grass soon ho hum
orangeblossom (04-29-2019)
Some Day, Some Day (05-02-2019)
maybe drop the driveshaft?
The following 2 users liked this post by JigJag:
Greg in France (04-30-2019),
The following 2 users liked this post by ptjs1:
Know anyone with a winch equipped Land Rover?
Hi Paul
Good thinking!
But before I go for the 'Nuclear Option' Today I took off the rear brake drums, which was unbelievably nearly impossible to do and then with all that friction removed, Tomorrow I will Start her up and play around with the gears
As I am hoping that some sort of Splash lubrication within the gearbox might free off the 'Slider Thingy' that enables you to change the gears, although of course I have no idea how a gearbox works, or even if the MGB Gods exist!
Although if they do you'll be the first to know!
I just need another run about for when the XJS is broken down
Good thinking!
orangeblossom (04-30-2019)
Hi Vee
I've got two of those already for moving furniture around but as I cannot get to the front of the Car, if the front Disc Brakes are seized on then that could be a problem
Also almost impossible to jack up the front end because there are filing cabinets each side that the P.O. kept his tools in and the Car is surrounded by Junk
So I will see what happens when I start her up and if I can get the gearbox to change gear then anything is possible
Thanks for your Suggestions
MGB Update
Took off the Brake Drums to Free off the Hubs which was a nightmare job to do in such a confined space but that was nothing compared to trying to put them back which was really the kind of stuff that bad dreams are made of
Then went up to the Front of the Car to free off the disc brakes and then with the help of a mate, I managed to Tow her out of that Garage with the Merc
Eventually we manged to turn her round so that She was facing the right way but as we hadn't got a Trailer I decided on the 'Nuclear Option' which was to Tow her home, as by this time She was rolling well sort of anyway
Though when we arrived at 'Orange Blossom Towers' we decided to try and Start her up to see if She would drive but as the Clutch return Spring was missing we tied a rope round the pedal so that we could pull it up by hand
Which with the benefit of hindsight was not the best idea I've ever had, as during 'Beta Testing' and nobody sitting behind the Wheel, as soon as we pulled on the rope She just took off all on her own which sort of caused a bit of an outbreak of Panic
Which meant that we had to run after her before She demolished the house and then jump in just like they do in the movies which was more exciting than a Bungee Jump although ten times more dangerous at which point we managed to stop her
Just in time!
Maybe not the best way that we could have done it, so lets just say that lessons have been learned and every available space in the Car was filled up with all sorts of interesting Junk, most of which I haven't even unpacked yet, including an Old Nokia Phone
Together with a Brand New Acetylene Torch with a Circle cutter still in the original wrapping although heavily corroded and in the centre glove box, was a Brand New Clutch Spring!
If only I had known!
There is also a Shed load of Spares that I'll go and pick up tomorrow
But as for the Car apart from the Seats which were completely rotten, after a wash and a bit of a Polish She's already looking a bit of a Bobby Dazzler!
But then I ran out of Polish! and the G.F has named her 'Rusty' because there isn't any rust on her at all!
No idea why that might be its still a mystery for a 40 year old MGB which by now should have turned into a real rust bucket
Just in time!
The following 2 users liked this post by orangeblossom:
Greg in France (05-02-2019),
katar83 (05-02-2019)
orangeblossom (05-02-2019)
Hi Leo
She's as solid as a rock and looks like She's been under sealed from New, all the Carpets were soaking wet but without any rust underneath and the engine Starts on the button and runs like a little Swiss Watch
The only bad points being that Pigeon 'Guano' has dissolved some of the paint on the bonnet and made it start to bubble up a bit but this was just a chemical reaction
None of the electrics work and neither does the Clutch unless you want to go driving around with the Steering Wheel in one hand and a bit of rope in the other, although the brakes are thankfully working very well
By the time I've got her sorted She will be a little beauty and even has a detachable Hard Top as well as overdrive and sounds amazing!
I'll try and put up a pic of her the next time I do an XJS post but this Shopping Trips not over as I'm after a 1980's R107 500SL to use as a daily driver
