Seat memory module LHB2165AA
Hi
I'm trying to help a guy, that is trying to fix a failing electric mirror. It seems the fault is in the control module, as the mirror will move, if 12V is applied directly.
Any tip to how to fix the box or find a used box ? I can see 2 boxes on eBay in US at around 185USD, is that the pricelevel to expect ?? Model XJS 1996 4.0, VIN SAJJAXFD4TS225422
Electric motor to what part? Mirror, seat, etc. The mirrors each have a fuse. The left mirror is under the dash fuse box. The right mirror fuse box is under the steering column. Assuming your Jaguar is RHD. If you are putting direct voltage to the mirror wiring, you are bypassing the fuse. The mirrors are inter connected (basically for mirror memory settings) with main console switch on the driver door. The mirror control knob will not function if any of the mirror fuse(s) are no good.
My own XJ-S is a 1977 with very manual mirrors, the type you adjust manually after rolling down the windows, so I have zero experience with this in XJ-S. My ‘40 is probably the same, it just never fails...
i will I’ll ask the mechanic to check fuses. As I understood it the fuses are in same side as the mirror they control ?
If what your friend needs is the mirror controller I can help with that.
However, before you throw a bunch of parts at the problem make sure that's what you need.
If you are sure all the associated fuses, relays and wiring are good then replace the controller.
My ,known good, controller can be had for half that.
I very rarely check in on the forums lately so contact me by phone/text @ 650-455-1110.
Steve
Steve
Steve
Steve
Johnny Vig
05-10-2019 08:54 PM
rlees
01-09-2012 09:52 AM
