Seat position Memory
The lumbar is an air bladder and what I have seen is the hose from the bladder to the pump deteriorates and falls apart. It is a pain to replace as the hose is swagged into the bladder.
I removed my hose and replaced it with a bit of vacuum hose, I slightly tore the entry to the bladder and had to seal it up with Polyurethane sealant and a cable tie.
Seat memory I would check connectors and seat position sensors, you will have to remove the seats to get at the sensors, my car does not have power seats so I can not help you with where the sensors are but they will be there.
