Seat removal
Seat removal
This is a 1996 XJS Convertible.
Hi all, I've pulled the gear pins from both front seats to remove and then repair the bad electric seat motors but I cant move the seats forward or back. Ive tried a hammer and 2x4 but they refuse to budge.
Any help on getting them to move?
Bill
Bill
Greg in France (11-14-2019)
It sounds like his seats motor isn't working, but he is trying to get to the bolts to pull the seat. However even with the front pins pulled he can't get it to move to get to the bolts
The following 2 users liked this post by Timeisrelative:
Greg in France (11-14-2019),
ptjs1 (11-14-2019)
Timeisrelative (11-14-2019)
Removed the "gear pins"? Are you referring to the electrical connectors that power the movement of each seat? Also, you have yet to remove any of the 4 mounting bolts on each seat? If this is the case -- disconnecting the power source to each seat has cut off any power to the seat. Therefore, the seat motor and any additional component will NOT function. Reconnect the "gear pins" and start over.
To update, earlier in the thread I was able to restore power. The seat is/was maxing out in the forward position wayyyy too early so I couldn't get to the rear bolts on the passenger seat. I did get the driver seat removed.
Also, with everyone's help and guidance I decided to shove a 2' long screwdriver up and down the rails. It got jammed at one point and I just kept ramming it in until it broke through.
After this, seat moved fully forward.
Thanks to everyone's help, seats and carpet are now out as of today! Water clean-up next!
2010 Jaguar XF Premium Luxury fishing pond installation.
Sorry, wrong post!!
Sorry, wrong post!!
