Shims for Front Brake Calipers
Just finished replacing front and rear rotors on my 96XJS 2+2.
The rears were absolutely a piece of cake.
Fronts were more of a chore (Mainly due to the shims placement) but I did manage to get it done.
Everything is working Great!
Now my question: On the fronts there are shims utilized on the Calipers.
1. What is the purpose of these shims?
2. What happens if they are left off?
Softball Paul
1996 XJS 2+2 Conv.
1957 XK140 Drop Head
Every Other English Sports Car known to Mankind
Softball Paul
1996 XJS 2+2 Conv.
1 = anti-squeal, they damp the vibrations that can occur between the pad and the disc that causes it
2 = nothing, except in my experience the brakes have more initial bite. orangeblossom has had problems when he fitted shims as they made the pads too tight a fit and jammed them against the rotors. Personally (takes cover) I never fit them.
Greg
Softball60 (03-01-2016)
Received 10,914 Likes
Are you talking about shims on the backside of the brake pads? If so, Greg explained.
Or are you talking about the shims to take up the gap between the steering arm and the caliper? If so, yes, reinstall the shims so the steering arm is not under strain and the toe-in setting stays correct
Or are you talking about the shims to centralize the caliper over the rotor? If you ever had them (unlikely), reinstall them only if you keep the existing calipers. If calipers are changed the need for the shims must be re-evaluated
The following 2 users liked this post by Doug:
Greg in France (03-01-2016),
"On the Calipers only. It is the long and short bolts (verticle) to each other that have holes in the bolt head for wire to secure.
Softball Paul "
If you mean the shim on the caliper fixing bolts, as in No 24 in this diagram:
![](http://www.jaguarclassicparts.com/illustrations/images/mh5696b.png)
Then you MUST measure the gap and shim it. The procedure is to attach the caliper top bolt and the steering arm top bolt and measure the gap between the arm and the caliper where the the bottom bolt will go through hole 15. Then get a shim to this same thickness and shove it in the gap and then insert the long bolt though the arm the shim the caliper and into the upright.
Greg
Softball Paul "
Greg
Kopi
02-19-2016 08:41 AM
skullbiker
01-31-2016 02:54 PM
