shock absorbers
yes, That's the setup my car and a customer car will be running at Wattkins Glen on a track day event in June. Both cars are being prepped this way with rear sway bars. This is a somewhat of a controversial setup as it's been suggested on Jag's to use a softer rear, no rear sway bar so the back end leans over and helps the car rotate. We are going to test this.
As someone stated shocks can only get you so far. As some point a spring upgrade is required.
Jess
H20boy
General Tech Help
10-31-2010 08:27 PM
