shock absorbers
Old 02-17-2018, 06:13 PM
VancouverXJ6's Avatar
Originally Posted by JessN16
So should we go Bilstein Yellow up front and KYB Gray in the back to get the firmest of both worlds? I want F.I.R.M.
Jess
Does anyone here have the exact part numbers handy?
Old 02-17-2018, 07:04 PM
icsamerica's Avatar
Received 1,371 Likes on 799 Posts
24-024457 front Bilstein.
Kg9122 rear KYB
Old 02-17-2018, 09:24 PM
Kg9122 rear KYB
Thanks, looks like a new set will cost nearly $500usd. Fun fun fun.
Old 02-17-2018, 09:47 PM
JessN16's Avatar
yes, That's the setup my car and a customer car will be running at Wattkins Glen on a track day event in June. Both cars are being prepped this way with rear sway bars. This is a somewhat of a controversial setup as it's been suggested on Jag's to use a softer rear, no rear sway bar so the back end leans over and helps the car rotate. We are going to test this.
As someone stated shocks can only get you so far. As some point a spring upgrade is required.
That's what this car is going to end up having. I bought a used Sport Pack RSB and will install it with newer struts and maybe springs as well. we're also going to play with the ride height a little (looking for a little front nose-down look, not much) and then change out the wheels/tires.
Jess
pinheaduk
02-07-2011 11:08 AM
H20boy
General Tech Help
10-31-2010 08:27 PM
webdesignhelper
07-25-2008 08:35 PM
04-26-2006 01:29 PM
Quick Reply: shock absorbers
