Should I use an RCB Breaker with a Welding Set?
Hi Guys
Made some good progress on the Battery Charging front but more of that later as its Tea Time!
But meanwhile does anyone know if I should use an RCB Breaker
On (A) Welding Set?
And or
(B) Battery Charger?
Or is there too much Chance of Tripping the RCB Breaker?
On (A) Welding Set?
And or
OB,
You only really need an RCD if you think there'll be a problem either through circuit overload or short circuit etc. It's used to protect the appliance and to protect the integrity and safety of your wiring electric supply. A standard battery conditioner won't need one. It will already have overload circuitry etc. If you think you've got an internal problem with that welder, I would definitely try and fix it before plugging it in.
Paul
Paul
orangeblossom (03-03-2024)
