Should you rinse off Car Shampoo?
Old 10-09-2017, 03:50 AM
orangeblossom's Avatar
Received 3,812 Likes on 2,639 Posts
Default Should you rinse off Car Shampoo?
Hi Guys
Many Car Shampoo manufacturers advertise their Products as leaving a streak free shine.
But should you rinse the Shampoo off before you dry it, or just dry off the Shampoo with a Microfibre cloth.
Old 10-09-2017, 05:22 AM
Received 10,518 Likes on 6,948 Posts
Rinse with rainwater, and then dry off.
Been doing it that way for waaaaay toooo many years.
And NO, parking it out in the rain after shampoo WILL NOT cut it.
orangeblossom (10-09-2017)
Old 10-09-2017, 06:57 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
You don't wash your hair with shampoo and don't rinse it, do you?
The following 2 users liked this post by Daim:
Grant Francis (10-09-2017), orangeblossom (10-09-2017)
Old 10-09-2017, 07:51 AM
ptjs1's Avatar
Received 3,096 Likes on 2,043 Posts
Car shampoo is a detergent that needs to be rinsed off. (As Daim says, you wouldn't just leave shampoo on your head!) The streak-free finish is achieved by including a water-repellant element in the shampoo that bonds to the bodywork. It's the equivalent of a wax coating which enables water dispersal and beading. The smaller you can get the water particles to break down, the less likely there is to be a streak finish. So you rinse off the detergent, leaving the thin coating and the car dries off streak-free. Well, that's the theory!
Paul
Old 10-09-2017, 08:03 AM
Paul
Hi Paul
Cheers!
The Perfect Explanation!
Old 10-09-2017, 08:04 AM
Yes but I'm not trying to get a Streak Free Shine!
Old 10-09-2017, 08:06 AM
I've done that 'Gig' already and you're right!
Old 10-09-2017, 08:43 AM
Daim's Avatar
My beautiful old C30 had immaculate paint and was washed weekly by hand. No matter if summer or winter. Storm or sun. Negative or positive tenperatures. I never had streaks. I would wash the car in the shade and then use a leather to remove all traces of (super hard) water. No streaks ever...
Old 10-12-2017, 12:19 PM
sidescrollin's Avatar
Uh.. just follow the directions?
If you are breaking dirt free it needs to be removed, water can rinse it away but using a cloth will likely create some small swirls.
Rinse, wash, rinse, then blow dry if you have the equipment.
If you don't have a reversing vac or leaf blower or dryer made specifically for cars, then get a silicone blade to wipe off the majority of the water and use compressed air to chase off the rest. hint: cheap silicone blades aren't worth it.
The following 2 users liked this post by sidescrollin:
orangeblossom (10-12-2017), ronbros (10-13-2017)
Old 10-12-2017, 04:37 PM
xjsv12's Avatar
I use drying wax after washing. five ml are mixed in a pumping garden sprayer. then wipe it with a microfiber.
The following 2 users liked this post by xjsv12:
Old 10-13-2017, 05:52 PM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
my paint was getting a little ruff when touched ,not showing tho.
decided to wash and go over it with Mothers Clay bar system.
unbelievable results , shines and smooth to the touch ,better than when 1st done paint work!
IT WORKS!!!!! a picture will not show the results, have to see in real life!
orangeblossom (10-14-2017)
Old 10-13-2017, 06:50 PM
ptjs1's Avatar
ronbros,
You MUST now wax the car. Clay barring (or clay-clothing) gives a beautiful finish but you've now removed all the wax protection from the paint, so it's really important to get a coat of wax protection back on.
Paul
The following 2 users liked this post by ptjs1:
orangeblossom (10-14-2017), ronbros (10-14-2017)
Old 10-13-2017, 06:58 PM
Andreas Schmieg's Avatar
The best way to dry your freshly washed car is still to drive it at 100 mph. :-)
The following 2 users liked this post by Andreas Schmieg:
Grant Francis (10-14-2017), orangeblossom (10-14-2017)
Old 10-14-2017, 12:15 AM
Just by way of an experiment, I washed my Merc with Car Shampoo and then I let it dry naturally, without either rinsing it off or drying it off with a microfiber cloth.
(don't use Chamois anymore)
It dried to a perfect streak free Shine!
What am I doing wrong?
Old 10-14-2017, 03:45 AM
ptjs1's Avatar
OB, that probably means:
- you've got a good coat of wax already n the car
- you're using decent shampoo with some wax or water-dispersing elements in it
- the water isn't too hard where you live
Keep doing what you're doing!
Paul
Old 10-14-2017, 05:12 AM
Hi Paul
No Wax but I Polished her with 'Mer' last year and am just about to do that again for this Year.
As for the Water its 'hard as a rock' where I live.
But I am using Turtle Wax Car Shampoo.
Is this the secret of the Perfect Shine
I certainly think so!
Old 10-24-2017, 05:09 PM
macdoesit's Avatar
Banned
I never put pooh or detergent on my ragtop, rinse water only and no high pressure water.
