Shout Out to Paul (Ptjs)
Hi Paul
On my 1995 4.0L XJS, I think that I have probably got the same Master Cylinder Servo with a Separate ABS on the other side of the Car as you have
Would this be the Teves MkV ?
My Question is: Do you bleed the Brakes on the MkV exactly the same as you do on the Teves Mk1V ?
Which you showed me how to do many Moons ago
I am also 'Guessing' that on this particular Set Up, there is no low pressure side of the System to Bleed
orangeblossom (07-16-2018)
orangeblossom
05-09-2018 03:12 AM
The Coupe
09-16-2011 08:59 AM
