Silly question, where is the sunrooof switch on my 89?
I have a 89 XJS and it is equipped with a sunroof but I cannot find the switch, The previous owner has smeared some sealer around the seams and did not use it. I never asked why or where the switch was. I want to remove the sealer and check the drains, as it may just be that simple, however I cannot find a switch. The only thing I can figure is when he swapped the console trim around the shifter where the window switches mount he installed one with no provision for a switch. I am thinking if I were to remove that panel, I may find the switch or harness below. I would rather not disturb it if I don't have to.
Any suggestions would be appreciated. Mark.
