Single coil retrofit
CEI is what you have. So you need .6 ohms if RGK is right, but I thought it was .5. Point is if it is significantly different from .5 or .6, don’t use it. I had an XJS with CEI and it just DEVOURED ignition amplifiers. I thought I was getting crappy Chinese ignition amps, but no, the problem was the coil ohm read was nowhere near spec. When I replaced the coil, the ignition amp never failed again. . A GM HEI amp (used inside the Lucas CEI ignition amp box) is like $50-$70, which isn’t worth risking compared with a coil.
The following 2 users liked this post by Jagsandmgs:
David84XJ6 (10-09-2024),
Greg in France (Yesterday)
Rex
Knowing nothing about Marelli ignition, I think the ohm rating will be OK, but you face another problem. I have a feeling the coil has two king leads to the dizzy? If I am right, these must be fired by separate signals from the Marelli system.
So (if I am right) the coil must be separated into two parts somehow, with each part running six cylinders - which we know is true because of the famous Marelli failure mode. This separation is the problem you face using it on a Lucas car, as one part of the Marelli coil will not fire 12 cylinders. The Lucas can only fire one coil, so I cannot see how you can use a Marelli coil in a standard Lucas system.
The Great Palm talks about this possibility and says an automatic coil selector might be a way round it; but that smacks of far too much complication for me! Also such devices are not designed to switch several thousand times a minute, rather to enable a single switch to a backup coil if one fails during a race, for example.
rgp (Yesterday)
Rex
1. I didn't like the fact it was so close to the dizzy and
2. I didn't like electrical connections on raised columns
I purchase a s/H marelli with a horizontal mount but the push on terminals are uncomfortably close to the small cross over vacuum pipe. I chect the resistance of the after market coil and the 2nd hand marelli and they were the same 00.5 ohms So I got a 4 pin plug wire up and it starts and runs ok. And to my eyes looks o/e as opposed to the anonymous after market one. We will see.. at the end of the day it's just a modern resin coil. 😊😊😊
Greg in France (Today)
