SJX RH door Locks
Be prepared for the Rube Goldberg assembly that makes up the door locking/unlocking function. Your job, which you’ve seemed resigned to accept, will be to find the broken/missing link in that assembly.
I can only hope that whatever it is that has broken, is still available for purchase.
Use the JDHT technical drawings to see if you can make sense of the assembly and match up the parts with what you have inside your door.
Since you’re gonna be in there anyways, might want to lube up the two vertical tracks, and the most important horizontal track on the bottom. I find that silicone paste works best and lasts longest.
XJ 4Ever
08-29-2017 03:23 PM
